claudioalmeiida
Pins RX/TX Serial UART
Fri Jul 25, 2014 5:33 am
Hello everyone, does anyone know tell me the number of pins RX/TX Serial UART on the module? Thank you
ame
Re: Pins RX/TX Serial UART
Fri Jul 25, 2014 8:31 am
There is one UART with one tx and one rx pin easily accessible.
I think there is another serial module in the Pi, but it uses the same GPIO pins.
Fri Jul 25, 2014 4:07 pm
There are two UARTS. A "mini" UART and a PL011 "full" UART. They are both available on various GPIOs as different ALT functions.
The BCM2385-ARM-Peripherals PDF shows how to use both of these and which GPIOs they can be on. As to which pins of the CM they are on, that depends on which ones you program them to use.
AndrewS
Sat Jul 26, 2014 5:15 pm
Each of the UARTs is available on three different sets of pins http://elinux.org/RPi_BCM2835_GPIOs
jackokring
Contact: ICQ
Sat Jul 26, 2014 5:31 pm
I think the default UART or console would be the best option as this needs minimal configuration.
Pi[NFA]=B256R0USB CL4SD8GB Raspbian Stock.
Pi[Work]=A+256 CL4SD8GB Raspbian Stock.
My favourite constant 1.65056745028
Return to “Compute Module”
