Compute Module Ethernet pinout
Posted: Wed Jul 02, 2014 5:26 pm
by kyle_IRIS
Hi there,
I was wondering if anyone could point me in the right direction for figuring out how to pin out an ethernet adapter from the compute SODIMM pins.
Thanks!
Re: Compute Module Ethernet pinout
Posted: Wed Jul 02, 2014 5:51 pm
by ShiftPlusOne
There is no ethernet. On the raspberry pi (model b), it's a separate chip, connected via USB.
Posted: Wed Jul 02, 2014 6:18 pm
by fruitoftheloom
ShiftPlusOne wrote:There is no ethernet. On the raspberry pi (model b), it's a separate chip, connected via USB.
http://www.raspberrypi.org/documentatio ... EMATIC.pdf
Posted: Wed Jul 02, 2014 10:27 pm
by AndrewS
If you're building your own board, I guess you could either use a USB->Ethernet adaptor (like the Model B does) or you could use an SPI-connected ethernet adaptor (which might be slower than a USB version).
Posted: Wed Aug 31, 2016 9:39 pm
by fui86
I'm just looking for Lan USB adapter for a custom board.
Now, I'm seeing this Pdf
https://www.raspberrypi.org/wp-content/ ... s-R1.0.pdf
But I can't understand reference to Rpi pinout.
Can you help me to understand?
Otherwise, someone have it done and can send to me his project ?
Posted: Sun Oct 02, 2016 11:12 pm
by JamesPi123
Try a OpenPi board
https://www.wirelessthings.net/openpi/ connected to a usb LAN adaptor
Posted: Mon Oct 03, 2016 6:27 pm
by GordonTGopher
Sadly WirelessThings shut down a few weeks ago, so no more opening boards available.
Gordon
