claudioalmeiida
Equivalent chip PAM2306AYPKE
Sat Jun 28, 2014 7:20 pm
Hello everyone, I could not find the PAM2306AYPKE to buy, so my question is if I can replace it by an equivalent, I found the LT3501: http://cds.linear.com/docs/en/datasheet/3501fd.pdf
Can I use this?
claudioalmeiida
Re: Equivalent chip PAM2306AYPKE
Tue Jul 01, 2014 2:20 pm
no one?
James Adams
Wed Jul 02, 2014 5:53 am
You could use PAM2306DYPAA (non fixed version). Or any supplies that will give you the right voltage(s) and current for your intended application. If you are designing a custom board you really need to calculate how much current each supply needs and design the powerchain appropriately.
James Adams
Raspberry Pi - COO & Hardware Lead
claudioalmeiida
Fri Jul 04, 2014 5:04 am
I'll look equivalent, the PAM2306DYPAA chip is very small, I will not get to work with him.
Thanks James, :)
mahjongg
Tue Sep 02, 2014 10:30 pm
data sheet of PAM2306 is here: http://diodes.com/datasheets/PAM2306.pdf
Return to “Compute Module”
