bifurkas
Re: CM4 launched
Thu Oct 22, 2020 5:27 pm
trejan wrote: Dual connectors like on the CM4 is quite common on other system-on-modules. They're nearly always spaced apart with one connector on each end.
Maybe. But this imposes certain restrictions on the technology of manufacturing the board.
W. H. Heydt
Re: CM4 launched
Thu Oct 22, 2020 6:56 pm
bifurkas wrote:
Thu Oct 22, 2020 5:14 pm
W. H. Heydt wrote: Don't you think the RPT folks tested for problems like that?
I am a practitioner. I do not use IO board, I make PCB and assemble boards myself. I do not know the capabilities of a RPT, but It will be difficult for me to properly solder the connectors
That's an entirely different issue, and one that has been noted in comments to others. I suspect that the RPT has a general expectation that *most* carrier boards will be machine soldered, though Dominic did mention soldering the connectors on the first prototype board by hand.
W. H. Heydt
Re: CM4 launched
Thu Oct 22, 2020 6:58 pm
Stop for a moment to consider the intended market for CMs generally and the CM4 in particular. I really don't see this as a problem.
bifurkas
Re: CM4 launched
Thu Oct 22, 2020 7:45 pm
W. H. Heydt wrote: Stop for a moment to consider the intended market for CMs generally and the CM4 in particular. I really don't see this as a problem.
I will remain unconvinced. Unfortunately, the use of CM4 is not available to me. In any case, the use of these connectors has narrowed the circle of CM users and increased the price.
Imperf3kt
Contact: Twitter
Re: CM4 launched
Thu Oct 22, 2020 8:19 pm
Are you an industrial user or a hobbyist who knows what he/she is doing?
If no, then you are not the target market.
Would you complain about not being able to get rocket fuel to build your own rocket if you weren't an astronautics engineer?
Or perhaps more suitable would be comparing getting ethanol-85 for your street car.
55:55:44:44:4C
52:4C:52:42:41
Re: CM4 launched
Thu Oct 22, 2020 8:36 pm
https://www.digikey.co.uk/product-detai ... ND/1969495
If the products offered by Raspberry Pi Trading not suitable just look elsewhere for a suitable product.
Out of interest what factual evidence do you have that the design of the CM4
"narrowed the circle of CM users and increased the price"
It has only just been released.
ejolson
Re: CM4 launched
Thu Oct 22, 2020 9:39 pm
I suspect the statement about increasing the price is based on the idea that a module with an SO-DIMM edge connector is cheaper to make than an equivalent module with two high-density sockets underneath. On the other hand, it is possible that putting all the traces on one edge would have necessitated another layer on the board or two, in which case the cost trade off is not clear.
Here in the peanut gallery, I can barely make out the difference between people who have built stuff and those who haven't.
In my opinion, it is impossible to tell how successful the design will be until many custom built carrier boards have been designed by independent third parties and then used in the field for some time. Hopefully, there won't be significant reliability problems, because the CM4 looks like a very sensible and versatile design.
W. H. Heydt
Re: CM4 launched
Thu Oct 22, 2020 9:51 pm
An apt comparison when consider that it only takes a reasonable lay knowledge of rockets to know that kerosene--which is readily available--has been used as rocket fuel. First stage Saturn V, for instance. I could name other fuels that have been used that have varying degrees of avialibility...
Gavinmc42
Re: CM4 launched
Fri Oct 23, 2020 2:02 am
It is the first CM I have been interested in.
Already alternative motherboards are appearing.
Those connectors do seem a better solution than the SODIMM type from a vibration issue.
With the 4 screw holes it should be pretty solid.
Time to get one and try it?
I'm dancing on Rainbows.
Gavinmc42
Re: CM4 launched
Fri Oct 23, 2020 2:53 am
Another reason to get the IO board?
https://www.phoronix.com/scan.php?page= ... -gpu&num=1
6 screen Pi?
trejan
Re: CM4 launched
Fri Oct 23, 2020 3:05 am
6 screen Pi?
GPUs don't work yet. Investigation thread over at viewtopic.php?f=98&t=288902
Gavinmc42
Re: CM4 launched
Fri Oct 23, 2020 3:28 am
Yet? :D
Thanks, will watch with interest that development.
Probably solved before any CM4's make it to Oz?
W. H. Heydt
Re: CM4 launched
Fri Oct 23, 2020 3:48 am
If you can find a company with them in stock, then by all means. I've played some with the original CM and CM3L. I agree that the CM4 is interesting, and the most interesting thing (at this point) is the CM4IO board.
Gavinmc42
Re: CM4 launched
Fri Oct 23, 2020 4:03 am
Yep the IO board if we can it, is not to badly priced.
That PCIe connector has some interesting possibilities.
https://coral.ai/products/pcie-accelerator
More stuff to learn :lol:
ejolson
Re: CM4 launched
Fri Oct 23, 2020 4:58 am
Is there an FPGA that has been verified to work in that slot on the IO board?
Gavinmc42
Re: CM4 launched
Fri Oct 23, 2020 5:34 am
A quick goo goo, first one I found looks interesting
https://www.knjn.com/FPGA-PCIe.html
Verified is going to have to wait until someone does it.
bensimmo
Re: CM4 launched
Fri Oct 23, 2020 8:51 am
Gumstix have already mode.a.board or two with coral on for you.
It would be interesting to see how much faster the direct PCIe interface than the usb3 one Google make.
racer993
Re: CM4 launched
Fri Oct 23, 2020 9:58 am
I have looking around to actually buy the CM4. Until now I've only found shops that have none in stock.
The Pimoroni Website however mentions the following: No wireless ships early November. Wireless ships mid-November.
Maybe the Raspberry Pi foundation can shed a light on availability of the CM4 and CM4IO board?
X-Gen
Re: CM4 launched
Fri Oct 23, 2020 11:50 am
I wonder if the 1GB versions will have slower RAM than the higher RAM versions?
I'm just waiting to see how TuringPi 2 will come out to be (in terms of converting the new socket to the old one).
They're using a 260 pin SoDimm, and the CM4 is still smaller than the Sodimm.
They're only populating a single CM per Sodimm.
https://turingpi.com/
Also, I wonder if the same speeds on the CM4 can be gotten as the Pi4B (including overclock). As the CM3 modules were slightly slower than their Pi3B counterparts.
If so, they'd need some heat sinks, and an active case fan.
hippy
Re: CM4 launched
Fri Oct 23, 2020 1:53 pm
6 screen Pi?
Oooh. That would be nice for building status and advertising displays with multiple monitors.
I'm wondering if MindVirus is dreaming up something to plug into it.
Re: CM4 launched
Fri Oct 23, 2020 2:19 pm
Foundation doesn't do production management, Trading do.
In short, we are in full production right now. Boards without wireless and IO boards should be available in a couple of weeks, wireless boards by December. Quite a few thousand of everything being made, so unless demand is very high those dates should be pretty accurate.
6by9
Re: CM4 launched
Fri Oct 23, 2020 2:27 pm
6 screen Pi?
Support for Nvidia 710 cards is already being discussed - viewtopic.php?f=98&t=288902
X-Gen
Re: CM4 launched
Fri Oct 23, 2020 8:41 pm
Did anyone test the power consumption on those boards at full CPU (and/or CPU+GPU) load?
W. H. Heydt
Re: CM4 launched
Fri Oct 23, 2020 9:23 pm
Based on what we know from the Pi4B, the CM4 shouldn't draw more than 1.8A--2A at the outside since it supplies 3.3v back to the carrier. Personally, for a 12v supply for the CM4IO board, I'd be looking for something around 2.5A to 3A (or perhaps more) to allow power for the PCIe connector as well as the--up to 4--USB 2 ports. The HDMI, CSI and DSI shouldn't take much.
Return to “Compute Module”
