Paul Webster
Contact: Twitter
CM4 launched
Mon Oct 19, 2020 7:34 am
https://www.raspberrypi.org/blog/raspbe ... -module-4/
Lots of newness including new form factor.
aBUGSworstnightmare
Re: CM4 launched
Mon Oct 19, 2020 8:28 am
I LIKE WHAT I SEE!
Looks great, also the optional WIFI interface is highly appreciated as it will ease product development to big extend!
And .. the price of USD35 for the bare IO board is great! But: where to buy it? No seller listed at the time of writing 10:31am CET or they show 'no stock' :cry:
And .. what I only saw on 'second view' - Single +5v PSU input (as the same PMIC as used on the Pi4 seems to be mounted).
Will definitely have to dig into the spec sheet later today ...
6by9
Re: CM4 launched
Mon Oct 19, 2020 9:30 am
It should be available via RS / okdo and Farnell as the normal main distributors.
It is freshly off the production line, so some will be still sorting out stock levels. Rest assured it is in full production and should be available.
For those wanting to know about PCI-e compatibility, I have one here with a Pericom PI7C9X 1 to 3 way PCI-e bridge, and Marvell 9215 4 port SATA card connected to that. (My VL805 USB3 card is still to be delivered). With a couple of extra kernel modules enabled (mainly CONFIG_ATA, and CONFIG_SATA_AHCI) it's the basis of my next NAS.
<24W with a pair of 8TB SATA drives spinning and a 240GB SSD. <10W with the spinning rust in standby.
Paul Webster
Contact: Twitter
Re: CM4 launched
Mon Oct 19, 2020 9:42 am
... and I expect that this will lead to more sales of the new IO board (compared to previous) for people who want the extra exposed capabilities of the CM4 compared to the RPi4 but can't make their own.
HermannSW
Re: CM4 launched
Mon Oct 19, 2020 9:48 am
price = (wifi ? 25 : 20) + (ram + ram/4) * 5 + (emmc/8 - emmc/32) * 5
https://static.raspberrypi.org/files/pr ... pdf#page=5
https://stamm-wilbrandt.de/working_with_FPGAs
Paul Webster
Contact: Twitter
Re: CM4 launched
Mon Oct 19, 2020 9:57 am
Is it possible for someone to mistakenly attach the CM4 (e.g. to the CMIO board) the wrong way around?
I ask because it looks like the connectors line up.
dp11
Re: CM4 launched
Mon Oct 19, 2020 10:06 am
The connectors are offset , so you could get it wrong but it would be obvious as the mounting holes would be very wrong.
PhilE
Re: CM4 launched
It's physically possible, but because the connectors are offset the silk screening on the carrier board should make it obvious. In the case of the CM4 I/O board the module ends up hanging off the edge of the baseboard if misoriented.
nixy82
Re: CM4 launched
Mon Oct 19, 2020 10:19 am
Hi
Great work guys, really happy to see the CM4 at last. Pats on the back to all who made this happen in such a short time frame!
Have a few questions if you can answer please
  • Are there going to be OrCAD schematics released for the CMIO4 (this was really helpful last time)
  • Are there going to gerbers released for the CMIO4 (this was really helpful last time)
  • Is the CM4 really not capable of sub zero temperature operation?
  • Is there going to be more power supply guidance in line with the CM3 type which gave a figure for the wattage on the +5V rail
Thanks again for the amazing work!
Andrew.
RaTTuS
Contact: Twitter YouTube
Re: CM4 launched
Mon Oct 19, 2020 10:37 am
Urge to buy rising ,,,,
the new dev board price is just excellent ....
Covfefe
Re: CM4 launched
Mon Oct 19, 2020 10:38 am
Hi
Andrew.
Kicad is our schematic publishing medium of choice. Available for the IO Board.
fanoush
Re: CM4 launched
Mon Oct 19, 2020 10:49 am
Exactly. Just not sure what Pi4 A can be - if that would have pci-e then it is also an option. But looks like the CM4+IO board is in fact the Pi4 I want :-) Very happy about it. Already have pci-e bridge in the drawer waiting for something like this and also the relatively cheap "Acorn CLE-215+ (Artix 7 FPGA)" pci-e fpga board (~70EUR stuff on ebay - EOLed mining board) is on the way.
crossbar
Re: CM4 launched
Mon Oct 19, 2020 10:59 am
Gavinmc42
Re: CM4 launched
Mon Oct 19, 2020 11:03 am
Great, I just finished laying out a motherboard for a Pi4 :oops:
It was for prototyping.
Guess what I will be using for production :D
The Kicad files will be handy.
I'm dancing on Rainbows.
cleverca22
Re: CM4 launched
Mon Oct 19, 2020 11:35 am
my only real complaint upon a quick glance, is that the ethernet PHY is on the CM4 board
if the PHY was on the CMIO4 instead, then the end-user would have the choice between getting another 12 gpio pins, or gigabit ethernet, and they could choose their own PHY
there are also switch IC's with RGMII, so you can skip the PHY directly, which would have let you make a CM4 based router
seperately from that, a question on documentation, i notice that it doesnt explain about how the HDMI lanes can be swapped
https://github.com/raspberrypi/linux/bl ... #L476-L484
basically, the PHY lets you swap the 4 lanes of the hdmi around, and the RPI4B has some lanes miswired slightly (likely to make routing simpler)
do the docs for the CM4 then mis-label the lanes, to match up with what the linux driver is expecting?
bensimmo
Re: CM4 launched
Mon Oct 19, 2020 11:40 am
Is it possible to add the PCIe with either M2 SATA/nvme adaptors) to the boot order?
Just curious.
cleverca22
Re: CM4 launched
Mon Oct 19, 2020 11:43 am
Just curious.
that would require drastic changes to the bootcode.bin in the eeprom, which i'm not sure the pi foundation would be up for, along with the issues of which sata driver to use
it would be simpler to get the CM4 with 8gig of flash, dedicated that to /boot, and then put / on your sata drive
bomblord
Re: CM4 launched
Mon Oct 19, 2020 12:14 pm
Pci 1x slot? Could you theoretically add a graphics card into this thing with a proper power setup???
piglet
Re: CM4 launched
Mon Oct 19, 2020 12:19 pm
Just curious.
I'd really like to boot from M.2 on CM-lite.
gsh
Re: CM4 launched
Mon Oct 19, 2020 12:29 pm
We've got NVME booting support on the list of things to do, but behind a couple of other things.
Gordon
Gordon Hollingworth PhD
plugwash
Re: CM4 launched
Mon Oct 19, 2020 12:52 pm
IIRC last time someone tried that (on a hacked up pi4 board) it didn't work because the controller was unable to deal with the large address space demands of a modern graphics card.
plugwash
Re: CM4 launched
Mon Oct 19, 2020 1:02 pm
Comparing the datasheets for the CM3+ and CM4 it seems we have lost the "bank 1" GPIO, is that correct?
crossbar
Re: CM4 launched
Mon Oct 19, 2020 1:20 pm
Minor correction :
In https://www.raspberrypi.org/products/co ... tenna-kit/ it is stated:
Obsolescence Statement
Compute Module 4 Antenna Kit will remain in production until at least January 2020
January 2020 ?
Probably meant : January 2028
bomblord
Re: CM4 launched
Mon Oct 19, 2020 1:30 pm
Hmm I wonder if any of the OS updates/hardware changes in the computer module could have inadvertently fixed that. I mean to even address the PCIE port it has to meet a certain set of minimum requirements.
piglet
Re: CM4 launched
Mon Oct 19, 2020 1:34 pm
Gordon
Great news. Thank you Gordon.
Return to “Compute Module”
