blachanc
compute module 3+ H264 decode max /recommended bitrate
Mon May 04, 2020 7:25 pm
Hi all,
quick question about the compute Module 3+
I am trying to find the detailed spec for the H264 decode.
I was explained in another thread about the video size & FPS spec, but I cannot find the recommended / max bitrate for the decoder let's say for a RTSP stream.
I read some non-official post mentioning 25M bps max, but no official mentions.
This is the only info I found about the decoding parameters:
https://www.element14.com/community/com ... ute-module
Broadcom BCM2837B0, Cortex-A53 64-bit SoC @ 1.2GHz
1Gbyte LPDDR2 SDRAM
Memory Options: 8 Gbytes, 16 Gbytes, 32 Gbytes eMMC Flash
Multimedia: H.264, MPEG-4 decode (1080p30), H.264 encode (1080p30), OpenGL ES 1.1, 2.0 graphics
SD card support: The CM3+ Lite brings the SD card interface to the module pins so a user can connect this to either an eMMC or SD card.
Environment: Operating temperature, -20° to +70°C
35u hard gold plated IO Pins
Thank you,
Ben
Autism/Asperger syndrome: what is your score on this quiz?
http://www.raspberrypi.org/forums/viewtopic.php?f=62&t=70191
Return to “Compute Module”
