Add microSD to CM: available controller in SOIC/TSSOP or similar?
Posted: Mon Jan 13, 2020 4:53 pm
by Killertechno
Hi to all users!
I would like to add externam microSD for storage purposes (CM1 or CM3).
There are several controllers but cases are not so easy to remove without specific instruments (if damaged).
I've seen controllers in SOIC package some time ago but meanwhile are obsolete devices so not available.
I'm searching for something I can repair (for prorotypes, then I'll move to actual devices) and desolder in easy way (so TSSOP, SOIC or similar).
I only found GL823 (not available from european suppliers and no documentation available).
Do somebody know something similar or do you suggest some specific controller?
Thanks.
Re: Add microSD to CM: available controller in SOIC/TSSOP or similar?
Posted: Mon Jan 13, 2020 5:11 pm
by trejan
Are you already using both SD controllers in the SoC?
Posted: Mon Jan 13, 2020 6:06 pm
by Killertechno
Hi treijan,
no, I would like to use eMMC for OS (on CM1 or CM3), then additional microSD only for storage to not loose data if CM will get damageds (to be removed only for emergencies).
Posted: Wed Jan 15, 2020 4:50 pm
by Frederir
For this you don't need an external controller, the compute module can drive an external SDCARD (but can not boot from it). I used SD0 on GPIO[22..27] for this purpose and it works well.
Posted: Wed Jan 15, 2020 5:36 pm
by Killertechno
I was planning USB interface to create separate board with all USB devices (microSD, wireless card....), starting from only microSD.
