capo349
Conxion sd card to module computer CM3+
Fri Dec 20, 2019 7:18 pm
Hi, how did I get a CM3 + computer module?
I am trying to connect an External sd to be able to store files there and I have two questions about it
1. This pin map shows two possibilities of connecting the SD I want to know where it connects correctly
https://elinux.org/RPi_BCM2835_GPIOs
2. What software configuration should be done according to the connection of the pins
at this moment the sd is connected to the datashet pins of the cm3 + module
W. H. Heydt
Re: Conxion sd card to module computer CM3+
Fri Dec 20, 2019 8:55 pm
Which model of CM3+ do you have? Only the CM3L+ has provision for an SD card interface. On the other versions, that interface goes to the on-board eMMC flash storage.
capo349
Fri Dec 20, 2019 11:18 pm
There are two versions according to the documentation module computer cm3 + is more complete than cm3 Lite
I have the CM3 +
W. H. Heydt
Sat Dec 21, 2019 2:59 am
I have the CM3 +
There are 4 versions of the CM3+. The CM3L+ has no on-board eMMC. The other three models have 8GB, 16GB or 32GB of eMMC flash. Do you have a CM3L+ or one of the ones with on-board eMMC flash storage?
capo349
Sun Dec 22, 2019 3:32 pm
I don't have the cm3 + lite
I have the cm3 + this has the possibility of connecting an external sd card.
Here is the reference.
https://www.raspberrypi.org/products/co ... le-3-plus/
W. H. Heydt
Sun Dec 22, 2019 9:35 pm
Yes, the CM3L+ can boot from an SD card. Indeed, unless you flash to right OTP bit, it has to.
capo349
Tue Dec 24, 2019 12:51 pm
Ok podrías indicarme como debo configurar la imagen
nomdediot
Fri Jan 03, 2020 10:52 am
With cm3 and cm3+ you can also extend the storage with an external SD card connected to GPIO 22 to 27. See also https://www.raspberrypi.org/forums/view ... 8&t=257309
Return to “Compute Module”
