lordbunnex
Contact: Google+
RPI -CMIO board and SD card
Fri Jul 19, 2019 9:36 am
i see this comes with SD Card slot but when i insert a card RPI -CMIO board dont seems like reading it
LordBunnex out!! :arrow:
aBUGSworstnightmare
Re: RPI -CMIO board and SD card
Fri Jul 19, 2019 11:33 am
Documentation of the Compute Module is here https://www.raspberrypi.org/documentati ... us_1p0.pdf
Have you set USB Boot jumper (J4) correctly (refer to schematic here https://www.raspberrypi.org/documentati ... IO_3p0.pdf)?
And ... you can't boot from uSD if you have a Compute Module WITH eMMC onboard! Only CM3L/CM3L+ can use uSD slot for booting.
lordbunnex
Contact: Google+
Fri Jul 19, 2019 12:26 pm
Thank you i think i have Raspberry Pi Compute Module IO Board Plus
Fri Jul 19, 2019 12:37 pm
You will find the Compute Module I/ O and Compute Module listed at the bottom of the products page under "Industrial Compute Module"
https://www.raspberrypi.org/products/
FYI double posting is not needed......
Retired disgracefully.....
Return to “Compute Module”
