framet
CM3+ not working with Image for CM3
Tue Jun 04, 2019 12:47 pm
Hello
I'm using a CM3 with the image from https://github.com/guysoft/RealtimePi.
This is based on the 4.14.y-rt version.
Today I've received the new CM3+ 32 GB and after flashing it with the same image the CM3+ will not boot. (colored screen)
Has someone experienced something similar? Because I thought there is no difference for a user when using CM3 or CM3+.
I need the preemptive patch but currently stuck when it comes to CM3+
Best regards
Framet
Re: CM3+ not working with Image for CM3
Tue Jun 04, 2019 2:26 pm
Hello
Best regards
Framet
AFAIAA you will need a newer kernel / firmware to support the 3B+, does the latest Raspbian Stretch OS function OK ?
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
W. H. Heydt
Tue Jun 04, 2019 2:35 pm
Yes, you need to patch to the latest firmware. What you've described is exactly the behavior of trying to boot a BCM2837B0 with BCM2837A0 firmware.
Return to “Compute Module”
