I tried to edit the config.txt to set it on pins 22/23 or 23/24 (as appeared default in i2c-gpio)
# Add new I2C
#dtoverlay=i2c-gpio,i2c_gpio_sda=22,i2c_gpio_scl=23
#dtoverlay=i2c1-bcm2708,sda1_pin=22,scl1_pin=23,pin_func=6
dtoverlay=i2c-gpio
dtoverlay=i2c-rtc,pcf8523
The device was detected as an i2c, but doesn't appear to be recognized.
$ i2cdetect -y 3
shows 68 at location 68, but probe return error
$ dmesg | grep pcf8523
rtc-pcf8523: probe of 1-0068 failed with error -121
$ sudo hwclock -D -r
hwclock from util-linux 2.29.2
hwclock: cannot open /dev/rtc: No such file or directory
No usable clock interface found.
hwclock: Cannot access the Hardware Clock via any known method.
$ sudo raspi-gpio get
GPIO 0: level=1 fsel=0 func=INPUT
GPIO 1: level=1 fsel=0 func=INPUT
GPIO 2: level=1 fsel=4 alt=0 func=SDA1
GPIO 3: level=1 fsel=4 alt=0 func=SCL1
GPIO 4: level=1 fsel=0 func=INPUT
GPIO 22: level=0 fsel=0 func=INPUT
GPIO 23: level=1 fsel=0 func=INPUT
GPIO 24: level=1 fsel=0 func=INPUT
