imanpakii
RPi CM3 not recognize by Windows 7
Tue Feb 05, 2019 6:16 pm
I received my RPI CM3 and I followed this link: https://www.raspberrypi.org/documentati ... lashing.md
But when the windows looking for the driver, it failed. Image
My system is
compute module I/O board v3.0
RPi CM3
Windows 7
Thank you for your help
USB driver issue.PNG (24.58 KiB) Viewed 703 times
silvia
Re: RPi CM3 not recognize by Windows 7
Fri Feb 08, 2019 9:53 am
Make sure the jumper J4 is in the 'EN' position. Then, plug the Dev Board to your computer's USB and power it up.
Run rpiboot as an admin -- this worked for me, I hope it helps!
gsh
Tue Feb 12, 2019 4:36 pm
As there is no driver found, it looks like the driver installation didn't occur...
Try again, using the installer in github
https://github.com/raspberrypi/usbboot/ ... ster/win32
Gordon Hollingworth PhD
Return to “Compute Module”
