M1LKYWVY
IO board and CM compatibility!
Mon Jan 14, 2019 1:33 pm
Good afternoon!
I have troubles with flashing emmc of CM. I have old IO board (it does not has slot for sd card), CM1 and CM3.
CM1 is not detectable with this IO board totally, CM3 has troubles with flashing viewtopic.php?f=98&t=230849&p=1416104#p1416104.
So i have some assumptions.
1. May be problem with IO board? May be it does not compatible with one of CM?
2. May be problem with software? May be i will success using old rpiboot and my old IO board and CM1?
If this has the right to exist, can i ask to anyone provide this software for raspbian to trying this suggestion?
3. May be they are broken in general? And solution is using new ones?
Thanks in advance!
Return to “Compute Module”
