gahigg1
Installing software on CM3
Wed Dec 26, 2018 6:43 pm
I just got the compute module 3 and I have trouble understanding how to upload code on it. My understanding is that I have to connect the I/O board to the host computer via micro usb connected to the USB slave port? What do I do now?
PhilE
Re: Installing software on CM3
Wed Dec 26, 2018 6:49 pm
gahigg1
Wed Dec 26, 2018 7:06 pm
It does not help me, I have the OS up and running. I just don't know how to install software on it. I want to use pip3 to install opencv. Since there is no internet connection, I am having issues.
Wed Dec 26, 2018 8:11 pm
Why do you have no internet connection ??
Thinking outside the box is better than burying your head in the sand...
rzusman
Wed Dec 26, 2018 8:28 pm
Wait.
Do you mean that the CM is up and running?
If so, get a USB-Ethernet converter, or a USB-WiFi dongle and use that to get the CM onto the Internet.
gahigg1
Mon Dec 31, 2018 3:37 pm
Yes the module is able to boot with raspbian lite, but I thought that files (such as git clones) could be put on the compute module over the usb slave port?
rzusman
Mon Dec 31, 2018 5:50 pm
If you follow the instructions PhilE posted above, you should be able to mount the CM as two volumes. Then (from a Linux host), you can just cp the files you need to the CM's Flash.
antoinebore
Wed Apr 17, 2019 6:25 am
Wait.
Can we use the uUSB-Ethernet converter and plus it into the uUSB Slave ?
Wed Apr 17, 2019 7:06 am
Wait.
AFAIAA the CM Carrier Board USB is Host unless the Jumper is moved to enable programming of the CM........
Return to “Compute Module”
