rego21
ENC28J60 on others SPIs
Thu Oct 18, 2018 1:46 pm
Hello all!
Yesterday i successful connected the ENC28J60 trough the SPI0 on Compute Module. However when i try it with SPI2 everything seems fines but doesn't assign an IP to the Compute Module. Im runing an DHCP server on my laptop and worked before with SPI0. Any clue what this problem can be?
Thanks!
PhilE
Re: ENC28J60 on others SPIs
Thu Oct 18, 2018 2:00 pm
When you create a post like this, try and anticipate what the first questions might be and provide the information upfront. Anyone hoping to help you will need to know how you configured the device - hardware and software - on spi0, and what you changed to try to use spi2 instead.
rego21
Thu Oct 18, 2018 2:12 pm
You are rigth sorry! For SPI0 i just edited the config.txt file on boot folder by adding:
dtoverlay=enc28j60
At the moment for SPI1 the config.txt is:
dtoverlay=enc28j60-spi1 //One custom overlay to work on SPI1
dtoverlay=spi1_cs1,cs0_spidev=off
Thu Oct 18, 2018 2:13 pm
Hello all!
Thanks!
This was original SPI0 post:
viewtopic.php?f=98&t=224915
adieu
PhilE
Thu Oct 18, 2018 2:15 pm
Since this is attached hardware people also need to know about the wiring used in each case.
You really didn't make it easier by starting a new topic, and it is in no way specific to the Compute Module.
Return to “Compute Module”
