Page 1 of 2
[SOLVED] ENC28J60 on SPI1
Posted: Tue Oct 16, 2018 4:05 pm
by rego21
Hello all!
I have one Compute Module and want to use the SPI1 interface wich are the GPIOS 17,18,19,20 and 21. However the SPI1 interface is ALT4 for these GPIOS. My question is: i want to know how to make these GPIO use their ALT4.
Thank you all!
Re: ENC28J60 on SPI1
Posted: Tue Oct 16, 2018 4:18 pm
by PhilE
There isn't an overlay that supports this yet, but there is one for spi2: https://github.com/raspberrypi/linux/bl ... verlay.dts
A simple search and replace of spi2 to spi1, and a change of the default irq pin (I'm guessing), and you should have a functional overlay. Assuming you called it enc28j60-spi1-overlay.dts, compile it with:
$ dtc [email protected] -I dts -O dtb -o enc28j60-spi1.dtbo enc28j60-spi1-overlay.dts
Don't worry if you get a few warnings - the dtc tool doesn't understand overlays so well.
Posted: Tue Oct 16, 2018 4:38 pm
by rego21
	compatible = "brcm,bcm2708";
	[email protected] {
		target = <&spi1>; //<&spi2>
		__overlay__ {
			/* needed to avoid dtc warning */
			#address-cells = <1>;
			#size-cells = <0>;
			status = "okay";
			eth1: [email protected]{
				compatible = "microchip,enc28j60";
				reg = <0>; /* CE0 */
				pinctrl-names = "default";
				pinctrl-0 = <&eth1_pins>;
				interrupt-parent = <&gpio>;
				interrupts = <39 0x2>; /* falling edge */
				spi-max-frequency = <12000000>;
				status = "okay";
Like this?
Posted: Tue Oct 16, 2018 5:17 pm
by PhilE
Yes - that looks good so far. Now change the default interrupt pin if you want to, compile it, copy it to /boot/overlays and add dtoverlay=enc28j60-spi1 to config.txt.
Posted: Wed Oct 17, 2018 9:07 am
by rego21
The command line you suggested
i belive the correct is
 dtc [email protected] -I dtb -O dts -o enc28j60-spi1.dtbo enc28j60-spi1-overlay.dts
. Your is giving me the error: Blob has incorrect magic number.
Posted: Wed Oct 17, 2018 9:22 am
by PhilE
No, the command is correct:
# Copy spi2 overlay source to a new file, changing spi2 to spi1 along the way
[email protected]:~$ sed -e 's/spi2/spi1/' enc28j60-spi2-overlay.dts > enc28j60-spi1-overlay.dts
# Now compile it
[email protected]:~$ dtc [email protected] -I dts -O dtb -o enc28j60-spi1.dtbo enc28j60-spi1-overlay.dts
Warning (unit_address_vs_reg): Node /[email protected] has a unit name, but no reg property
'-I dts' tells dtc that the input file is in DTS (Device Tree source) format. '-O dtb' asks for the output to be in DTB format (Device Tree binary). ''-o enc28j60-spi1.dtbo' tells it where to write the output, and the final parameter is the source file.
Posted: Wed Oct 17, 2018 9:59 am
by rego21
# Now compile it
Ok i did the all the step but nothing working... Im using the pins SPI1 :
18 SPI1 CE0
19 SPI1 MISO PWM1
20 SPI1 MOSI GPCLK0
21 SPI1 SCLK
Im also using the SPI0:
8 SPI0 CE0 N
9 SPI0 MISO
10 SPI0 MOSI
11 SPI0 SCLK
The last one is working without problem.
Posted: Wed Oct 17, 2018 10:10 am
by PhilE
Show the output of "raspi-gpio get 18-21" and "lsmod" when using the enc28j60-spi1 overlay.
Posted: Wed Oct 17, 2018 10:16 am
by rego21
lsmod give me this
Module Size Used by
cfg80211 527100 0
rfkill 21373 2 cfg80211
spidev 7034 0
snd_bcm2835 23131 0
snd_pcm 97825 1 snd_bcm2835
snd_timer 22706 1 snd_pcm
spi_bcm2835aux 5235 0
snd 68784 3 snd_timer,snd_bcm2835,snd_pcm
spi_bcm2835 7424 0
bcm2835_gpiomem 3791 0
fixed 3029 0
uio_pdrv_genirq 3718 0
uio 10166 1 uio_pdrv_genirq
ip_tables 12512 0
x_tables 20921 1 ip_tables
ipv6 384613 16
I didnt installed gpio-get but i wil dot it and give you the output. Thanks for your help!
by PhilE
 sudo apt-get install raspi-gpio
Posted: Wed Oct 17, 2018 10:19 am
by PhilE
I suspect your overlay is failing to load. "sudo vcdbg log msg" will show you the log messages from the firmware - they are sent to stderr, so if you want to put them in a file you will need "sudo vcdbg log msg >& vcdbg.txt" (or "sudo vcdbg log msg > vcdbg.txt 2>&1" for a simpler shell).
Posted: Wed Oct 17, 2018 11:04 am
by rego21
My gpio get :
BANK0 (GPIO 0 to 27):
GPIO 0: level=1 fsel=0 func=INPUT
GPIO 1: level=1 fsel=0 func=INPUT
GPIO 2: level=1 fsel=0 func=INPUT
GPIO 3: level=1 fsel=0 func=INPUT
GPIO 4: level=1 fsel=0 func=INPUT
GPIO 5: level=1 fsel=0 func=INPUT
GPIO 6: level=1 fsel=0 func=INPUT
GPIO 7: level=1 fsel=1 func=OUTPUT
GPIO 8: level=1 fsel=1 func=OUTPUT
GPIO 9: level=0 fsel=4 alt=0 func=SPI0_MISO
GPIO 10: level=0 fsel=4 alt=0 func=SPI0_MOSI
GPIO 11: level=0 fsel=4 alt=0 func=SPI0_SCLK
GPIO 12: level=0 fsel=0 func=INPUT
GPIO 13: level=0 fsel=0 func=INPUT
GPIO 14: level=0 fsel=4 alt=0 func=TXD0
GPIO 15: level=1 fsel=4 alt=0 func=RXD0
GPIO 16: level=0 fsel=0 func=INPUT
GPIO 17: level=0 fsel=0 func=INPUT
GPIO 18: level=1 fsel=1 func=OUTPUT
GPIO 19: level=0 fsel=3 alt=4 func=SPI1_MISO
GPIO 20: level=0 fsel=3 alt=4 func=SPI1_MOSI
GPIO 21: level=0 fsel=3 alt=4 func=SPI1_SCLK
GPIO 22: level=0 fsel=0 func=INPUT
GPIO 23: level=0 fsel=0 func=INPUT
GPIO 24: level=0 fsel=0 func=INPUT
GPIO 25: level=0 fsel=0 func=INPUT
GPIO 26: level=0 fsel=0 func=INPUT
GPIO 27: level=0 fsel=0 func=INPUT
BANK1 (GPIO 28 to 45):
GPIO 28: level=0 fsel=0 func=INPUT
GPIO 29: level=0 fsel=0 func=INPUT
GPIO 30: level=0 fsel=0 func=INPUT
GPIO 31: level=0 fsel=0 func=INPUT
GPIO 32: level=0 fsel=0 func=INPUT
GPIO 33: level=0 fsel=0 func=INPUT
GPIO 34: level=1 fsel=0 func=INPUT
GPIO 35: level=1 fsel=0 func=INPUT
GPIO 36: level=1 fsel=0 func=INPUT
GPIO 37: level=0 fsel=0 func=INPUT
GPIO 38: level=0 fsel=0 func=INPUT
GPIO 39: level=0 fsel=0 func=INPUT
GPIO 40: level=0 fsel=0 func=INPUT
GPIO 41: level=0 fsel=0 func=INPUT
GPIO 42: level=0 fsel=0 func=INPUT
GPIO 43: level=0 fsel=0 func=INPUT
GPIO 44: level=0 fsel=0 func=INPUT
GPIO 45: level=0 fsel=0 func=INPUT
BANK2 (GPIO 46 to 53):
GPIO 46: level=1 fsel=0 func=INPUT
GPIO 47: level=0 fsel=1 func=OUTPUT
GPIO 48: level=0 fsel=4 alt=0 func=SD0_CLK
GPIO 49: level=1 fsel=4 alt=0 func=SD0_CMD
GPIO 50: level=1 fsel=4 alt=0 func=SD0_DAT0
GPIO 51: level=1 fsel=4 alt=0 func=SD0_DAT1
GPIO 52: level=1 fsel=4 alt=0 func=SD0_DAT2
GPIO 53: level=1 fsel=4 alt=0 func=SD0_DAT3
The output of sudo vcdbg log msg :
001849.674: brfs: File read: 142 bytes
002236.935: brfs: File read: /mfs/sd/kernel.img
002236.960: Loading 'kernel.img' to 0x8000 size 0x42d210
002237.002: No kernel trailer - assuming DT-capable
002237.030: brfs: File read: 4379152 bytes
002239.802: brfs: File read: /mfs/sd/bcm2708-rpi-cm.dtb
002239.826: Loading 'bcm2708-rpi-cm.dtb' to 0x435210 size 0x3aee
002249.656: gpioman: gpioman_get_pin_num: pin NUM_CAMERAS not defined
002302.302: gpioman: gpioman_get_pin_num: pin POWER_LOW not defined
002304.595: brfs: File read: 15086 bytes
002306.526: brfs: File read: /mfs/sd/config.txt
002306.840: dtparam: spi=on
002311.529: dtparam: audio=on
002319.106: brfs: File read: 1633 bytes
002325.114: brfs: File read: /mfs/sd/overlays/enc28j60-spi1.dtbo
002331.854: Loaded overlay 'enc28j60-spi1'
002351.774: brfs: File read: 1317 bytes
002357.087: brfs: File read: /mfs/sd/overlays/spi1-1cs.dtbo
002365.671: Loaded overlay 'spi1-1cs'
003284.835: gpioman: gpioman_get_pin_num: pin PWML not defined
003284.855: gpioman: gpioman_get_pin_num: pin PWMR not defined
003291.931: gpioman: gpioman_get_pin_num: pin PWML not defined
003291.951: gpioman: gpioman_get_pin_num: pin PWMR not defined
003296.317: Device tree loaded to 0x1bfebe00 (size 0x41cf)
003297.590: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
004954.263: vchiq_core: vchiq_init_state: slot_zero = 0x5b580000, is_master = 1
004959.373: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
Posted: Wed Oct 17, 2018 11:15 am
by PhilE
You may need to disable spidev on spi1.0 because the enc28j60 has a kernel driver - use "dtoverlay=spi1-1cs,cs0_spidev=off".
Posted: Wed Oct 17, 2018 11:30 am
by rego21
Nothing... I check ifconfig :
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
However the SPI seems to be ok
Posted: Wed Oct 17, 2018 11:33 am
by PhilE
Did you change the interrupt pin assignment?
What does "dmesg" report?
Posted: Wed Oct 17, 2018 11:41 am
by rego21
Im not using the INT pin, i really need it?
0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.59+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1047 Sun Oct 29 11:47:10 GMT 2017
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi Compute Module Rev 1.0
[ 0.000000] cma: Reserved 8 MiB at 0x1b400000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c0914e10, node_mem_map db010000
[ 0.000000] Normal zone: 1008 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113680
[ 0.000000] Kernel command line: bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:39:D9:43 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=bff42074-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 435944K/458752K available (5950K kernel code, 491K rwdata, 1948K rodata, 396K init, 725K bss, 14616K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xdc800000 - 0xff800000 ( 560 MB)
lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc05d7a48 (5951 kB)
.init : 0xc0841000 - 0xc08a4000 ( 396 kB)
.data : 0xc08a4000 - 0xc091ef48 ( 492 kB)
.bss : 0xc091ef48 - 0xc09d4648 ( 726 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000031] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000077] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000177] bcm2835: system timer (irq = 27)
[ 0.000650] Console: colour dummy device 80x30
[ 0.001412] console [tty1] enabled
[ 0.001466] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060363] pid_max: default: 32768 minimum: 301
[ 0.060828] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060898] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.062187] Disabling memory control group subsystem
[ 0.062396] CPU: Testing write buffer coherency: ok
[ 0.062498] ftrace: allocating 21715 entries in 64 pages
[ 0.180706] Setting up static identity map for 0x8200 - 0x8238
[ 0.182783] devtmpfs: initialized
[ 0.192500] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.193014] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.193114] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.194428] pinctrl core: initialized pinctrl subsystem
[ 0.195934] NET: Registered protocol family 16
[ 0.198401] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.207996] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.208090] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.208231] Serial: AMBA PL011 UART driver
[ 0.211193] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.212747] irq: no irq domain found for /soc/[email protected] !
[ 0.262428] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
[ 0.265198] SCSI subsystem initialized
[ 0.265569] usbcore: registered new interface driver usbfs
[ 0.265749] usbcore: registered new interface driver hub
[ 0.265990] usbcore: registered new device driver usb
[ 0.270781] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:09
[ 0.272737] clocksource: Switched to clocksource timer
[ 0.326903] VFS: Disk quotas dquot_6.6.0
[ 0.327105] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.327478] FS-Cache: Loaded
[ 0.327876] CacheFiles: Loaded
[ 0.347281] NET: Registered protocol family 2
[ 0.348724] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.348882] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.349015] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.349155] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.349223] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.349569] NET: Registered protocol family 1
[ 0.350381] RPC: Registered named UNIX socket transport module.
[ 0.350459] RPC: Registered udp transport module.
[ 0.350499] RPC: Registered tcp transport module.
[ 0.350535] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.351692] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 0.354361] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.375139] FS-Cache: Netfs 'nfs' registered for caching
[ 0.376991] NFS: Registering the id_resolver key type
[ 0.377103] Key type id_resolver registered
[ 0.377147] Key type id_legacy registered
[ 0.381651] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.382121] io scheduler noop registered
[ 0.382187] io scheduler deadline registered (default)
[ 0.382704] io scheduler cfq registered
[ 0.388705] BCM2708FB: allocated DMA memory 5b500000
[ 0.388838] BCM2708FB: allocated DMA channel 0 @ dc80d000
[ 0.397157] Console: switching to colour frame buffer device 82x26
[ 0.407638] bcm2835-rng 20104000.rng: hwrng registered
[ 0.410455] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 0.416898] vc-sm: Videocore shared memory driver
[ 0.444485] brd: module loaded
[ 0.459783] loop: module loaded
[ 0.462548] Loading iSCSI transport class v2.0-870.
[ 0.466243] usbcore: registered new interface driver smsc95xx
[ 0.468982] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.699891] Core Release: 2.80a
[ 0.702553] Setting default values for core params
[ 0.705259] Finished setting default values for core params
[ 0.908372] Using Buffer DMA mode
[ 0.910980] Periodic Transfer Interrupt Enhancement - disabled
[ 0.913625] Multiprocessor Interrupt Enhancement - disabled
[ 0.916274] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.918951] Dedicated Tx FIFOs mode
[ 0.922160] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
[ 0.927798] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.940981] dwc_otg: Microframe scheduler enabled
[ 0.941119] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc0451694
[ 0.943752] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451970 length 36
[ 0.946378] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
[ 0.949164] dwc_otg 20980000.usb: DWC OTG Controller
[ 0.951874] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 0.954736] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 0.957420] Init: Port Power? op_state=1
[ 0.959963] Init: Power Port (0)
[ 0.962882] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.965566] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.968186] usb usb1: Product: DWC OTG Controller
[ 0.970753] usb usb1: Manufacturer: Linux 4.9.59+ dwc_otg_hcd
[ 0.973390] usb usb1: SerialNumber: 20980000.usb
[ 0.977139] hub 1-0:1.0: USB hub found
[ 0.979751] hub 1-0:1.0: 1 port detected
[ 0.983163] dwc_otg: FIQ enabled
[ 0.983173] dwc_otg: NAK holdoff enabled
[ 0.983179] dwc_otg: FIQ split-transaction FSM enabled
[ 0.983200] Module dwc_common_port init
[ 0.983719] usbcore: registered new interface driver usb-storage
[ 0.986697] mousedev: PS/2 mouse device common for all mice
[ 0.990874] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.994145] bcm2835-cpufreq: min=700000 max=700000
[ 0.997415] sdhci: Secure Digital Host Controller Interface driver
[ 1.000101] sdhci: Copyright(c) Pierre Ossman
[ 1.003245] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
[ 1.006368] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.009674] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.012592] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.015863] usbcore: registered new interface driver usbhid
[ 1.018667] usbhid: USB HID core driver
[ 1.022609] vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
[ 1.027470] [vc_sm_connected_init]: start
[ 1.037831] [vc_sm_connected_init]: end - returning 0
[ 1.041275] Initializing XFRM netlink socket
[ 1.044152] NET: Registered protocol family 17
[ 1.047015] Key type dns_resolver registered
[ 1.051467] registered taskstats version 1
[ 1.061573] uart-pl011 20201000.serial: cts_event_workaround enabled
[ 1.064808] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 1.899177] console [ttyAMA0] enabled
[ 1.908241] sdhost: log_buf @ db513000 (5b513000)
[ 1.992822] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.001282] of_cfs_init
[ 2.026813] of_cfs_init: OK
[ 2.033231] Waiting for root device PARTUUID=bff42074-02...
[ 2.043465] random: fast init done
[ 2.223726] mmc0: new high speed MMC card at address 0001
[ 2.233055] mmcblk0: mmc0:0001 4FEACB 3.64 GiB
[ 2.240733] mmcblk0boot0: mmc0:0001 4FEACB partition 1 4.00 MiB
[ 2.249980] mmcblk0boot1: mmc0:0001 4FEACB partition 2 4.00 MiB
[ 2.259113] mmcblk0rpmb: mmc0:0001 4FEACB partition 3 512 KiB
[ 2.269397] mmcblk0: p1 p2
[ 2.404148] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.417682] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.435694] devtmpfs: mounted
[ 2.442821] Freeing unused kernel memory: 396K
[ 2.449976] This architecture does not have kernel memory protection.
[ 2.923344] systemd[1]: System time before build time, advancing clock.
[ 3.058755] NET: Registered protocol family 10
[ 3.087089] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.134572] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 3.162433] systemd[1]: Detected architecture arm.
[ 3.182655] systemd[1]: Set hostname to <raspberrypi>.
[ 3.523509] uart-pl011 20201000.serial: no DMA platform data
[ 4.177387] systemd[1]: Listening on udev Control Socket.
[ 4.191305] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.206684] systemd[1]: Listening on Journal Socket.
[ 4.219231] systemd[1]: Reached target Swap.
[ 4.231098] systemd[1]: Listening on Syslog Socket.
[ 4.245000] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.265346] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 16.415493] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 16.790231] systemd-journald[101]: Received request to flush runtime journal from PID 1
[ 18.582685] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 24.171979] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 24.523838] enc28j60 spi1.0: enc28j60 Ethernet driver 1.02 loaded
[ 24.542097] net eth0: enc28j60 driver registered
Posted: Wed Oct 17, 2018 11:46 am
by PhilE
If you have had the enc28j60 on SPI0 then you may not need it, but I think you might.
The dmesg output shows the driver being loaded and registering, so I'm surprised it didn't show up in the lsmod output. Have you changed something else?
Posted: Wed Oct 17, 2018 11:52 am
by rego21
I will try to connect the INT pin, but i think the problem is not there. I will give it a try
I followed your steps:
1. Create dts file an compile it for spi1
2. edit config.txt and add the lines:
3.Rebbot system
Posted: Wed Oct 17, 2018 11:55 am
by PhilE
Have you had the enc28j60 working on SPI0, or did you just mean the SPI0 is working for something else?
Posted: Wed Oct 17, 2018 12:03 pm
by rego21
Yeah SPI0 is working for something else
Posted: Wed Oct 17, 2018 1:26 pm
by rego21
Tried on SPI0 with the INT pin and no success...
[email protected]:~$ dmesg | grep spi
[   15.053446] enc28j60 spi0.0: enc28j60 Ethernet driver 1.02 loaded
Posted: Wed Oct 17, 2018 1:31 pm
by PhilE
Then I am out of ideas for now - sorry.
Posted: Wed Oct 17, 2018 2:26 pm
by rego21
The dmesg | grep -e spi0.0 -ie eth output seems correct:
I believe the problem can be the file /network/interfaces
Posted: Wed Oct 17, 2018 2:33 pm
by PhilE
You shouldn't need to change anything else in Raspbian.
Posted: Wed Oct 17, 2018 3:45 pm
by rego21
Now ifconfig show me the eth0 however doesnt assign an inet addr to it
