PhilE
Re: ENC28J60 on SPI1
Wed Oct 17, 2018 3:51 pm
You'll need to enable DHCP on that interface (in whatever distribution you are using).
rego21
Wed Oct 17, 2018 9:57 pm
It's working but only whe connected to the router. When directly connected to the PC i cant ssh...
PhilE
Thu Oct 18, 2018 7:57 am
That's not surprising unless your PC is running a DHCP server. Try giving the Pi and PC static IP addresses, or configure the PC to bridge the Ethernet port to WiFi to allow the Pi to share it (depending on your requirements).
rego21
Thu Oct 18, 2018 1:55 pm
See my new post! Thanks for your help i fixed the problem today! See if you can help me with : viewtopic.php?f=98&t=225043
Return to “Compute Module”
