Maykef
Problems with rpiboot after mounting external sd card
Sun Oct 14, 2018 12:01 pm
Hi all,
I cannot flash the CM3 using ./rpiboot after mounting an sd card and moving boot files to it. Rpiboot never recognises the CM.
Any ideas how to solve this?
aBUGSworstnightmare
Re: Problems with rpiboot after mounting external sd card
Sun Oct 14, 2018 1:28 pm
As you want to use rpoboot I assume you have a CM3 (with eMMC) and not CM3L (without eMMC).
On the CMIO the uSD can only be used with CM3L.
Maykef
Sun Oct 14, 2018 1:58 pm
You assume well.
Problem appeared after I moved boot files to external sd card in order to avoid problems when installing larger file systems like opencv.
Tried in Linux and Mac OS, but I just cannot flash it. Waiting for BCM2835/6/7 gets stuck and does nothing.
aBUGSworstnightmare
Sun Oct 14, 2018 2:06 pm
If you need more flash than 4GB you may want to use the NEC CM3 which has 16GB eMMC storage mounted.
Or use uSD with a CM3L.
Maykef
Sun Oct 14, 2018 2:09 pm
Thanks for the advice on the CM NEC edition.
That doesn't solve my present problem though.
hippy
Sun Oct 14, 2018 3:00 pm
Delete or rename "bootcode.bin" on the SD Card.
Or perhaps remove the SD Card, power-up then insert the card -- I have no idea how safe hot-insertion is.
When "bootcode.bin" is present the Pi will try to boot from the SD Card before trying other means of booting so never gets to a state where rpiboot sees it again as something it can upload to.
Return to “Compute Module”
