[SOLVED} what is the Compute Module's pin_config section?
Posted: Mon Oct 08, 2018 11:04 am
by gks9754
I have done detecting dual camera on my CM3 IO board.
I'm trying to use that two cameras but I'm wondering .."The Compute Module's pin_config section needs the second camera's LED and power enable pins configured" and "In the Compute Module's pin_defines section of the dts file, change the NUM_CAMERAS parameter to 2 and add the following:" How to do that...?
I thing I should write on somewhere..but i don't know which file I should write on
"pin@p31 { function = "output"; termination = "no_pulling"; };" and
"pin_define@CAMERA_1_LED { type = "internal"; number = <30>; };
pin_define@CAMERA_1_SHUTDOWN { type = "internal"; number = <31>; };
pin_define@CAMERA_1_UNICAM_PORT { type = "internal"; number = <0>; };
pin_define@CAMERA_1_I2C_PORT { type = "internal"; number = <0>; };
pin_define@CAMERA_1_SDA_PIN { type = "internal"; number = <28>; };
pin_define@CAMERA_1_SCL_PIN { type = "internal"; number = <29>; };"
I read this https://www.raspberrypi.org/documentati ... -camera.md
Re: what is the Compute Module's pin_config section?
Posted: Mon Oct 08, 2018 11:16 am
by PhilE
You'll find the information you need in the Pin Configuration documentation.
Posted: Thu Oct 11, 2018 5:14 am
by gks9754
Turns out I already did it . but my program doesn't work..
import time
import picamera
import RPi.GPIO as GPIO
CameraOne = picamera.PiCamera(0)
CameraTwo = picamera.PiCamera(1)
CameraOne.resolution = (854,480)
CameraTwo.resolution = (854,480)
CameraOne.framerate = 30
CameraTwo.framerate = 30
GPIO.setmode(GPIO.BCM)
with picamera.PiCamera() as camera:
    CameraOne.start_preview(resolution = (854,480))
    time.sleep(1)
    CameraTwo.start_preview(resolution = (854,480))
    time.sleep(5)
    CameraOne.capture('/home/pi/Desktop/capture1.jpg')
    CameraTwo.capture('/home/pi/Desktop/capture2.jpg')
    CameraOne.stop_preview
    CameraTwo.stop_preview
It shows me like this
Python 3.5.3 (/usr/bin/python3)
>>> %Run recording_test2.py
  File "/usr/lib/python3/dist-packages/picamera/camera.py", line 345, in __init__
    }[(GPIO.RPI_REVISION, camera_num)]
KeyError: (3, 1)
During handling of the above exception, another exception occurred:
  File "/home/pi/Desktop/PIcamera/recording_test2.py", line 6, in <module>
  File "/usr/lib/python3/dist-packages/picamera/camera.py", line 350, in __init__
    GPIO.RPI_REVISION, camera_num))
picamera.exc.PiCameraError: Unable to determine default GPIO LED pin for RPi revision 3 and camera num 1
Posted: Thu Oct 11, 2018 6:37 am
by 6by9
Before trying picamera, does raspistill work for both cameras? Use -cs 0 and -cs 1 to select the camera.
Read the docs for picamera https://picamera.readthedocs.io/en/rele ... l#picamera
The led_pin parameter can be used to specify the GPIO pin which should be used to control the camera’s LED via the led attribute. If this is not specified, it should default to the correct value for your Pi platform. You should only need to specify this parameter if you are using a custom DeviceTree blob (this is only typical on the Compute Module platform).
Posted: Mon Oct 15, 2018 8:25 am
by gks9754
Do you mean I'm going to do "raspistill -o image.jpg" and "raspistill -l image.jpg"??(I couldn't understand -cs0, -cs1)
I tried to do "raspistill -o image.jpg" it shows me CAM1 screen, when I did "raspistill -l image.jpg" It also shows me CAM1 screen.
I think I have to do something for working raspistill.
what should I do..
Posted: Mon Oct 15, 2018 8:45 am
by 6by9
Note that -cs X matches the CAMERA_X_ defines in pins_config section. With the default setup of
pin_define@CAMERA_0_UNICAM_PORT { type = "internal"; number = <1>; };
-cs 0 will select the camera connected to CAM1, and -cs 1 will select the camera connected to CAM0. The reasoning is that CAM1 can support 4 lane CSI-2 (vs only 2 lanes on CAM0) and therefore being the more capable port is the one that should be used first. It's also the one that is used on all other flavours of the Pi.
Posted: Mon Oct 15, 2018 9:57 am
by gks9754
Thanks!!! I've checked what you said
It works well!!
but when I do
import time
import picamera
CameraOne.resolution =(854,480)
CameraTwo.resolution =(854,480)
    time.sleep(1)
It shows me the same error..
>>> %Run 'dual camera test.py'
KeyError: (3, 1)
  File "/home/pi/dual camera test.py", line 6, in <module>
could you tell me more details??
Do I have to change the picamera library..?
Posted: Mon Oct 15, 2018 10:04 am
by 6by9
I'll point you straight back to my earlier post
CameraOne = picamera.PiCamera(camera_num=0,led_pin=2)
CameraTwo = picamera.PiCamera(camera_num=1,led_pin=30)
Posted: Thu Oct 18, 2018 8:20 am
by gks9754
I did it!!!!!!!!!!!
thanks!!!!
