using CAM0 on the CM3
Posted: Sun Oct 07, 2018 8:58 am
I read https://www.raspberrypi.org/documentati ... -camera.md and https://www.raspberrypi.org/forums/view ... p?t=193577
I followed those three steps.
"wget https://www.raspberrypi.org/documentati ... ualcam.dts"
"dtc -I dts -O dtb -o dt-blob-dualcam.dtb dt-blob-dualcam.dts"
"sudo cp dt-blob-dualcam.dtb /boot/dt-blob.bin" OR "sudo cp dt-blob-dualcam.dtb /boot/overlays"
when I did the first step "wget https://www.raspberrypi.org/documentati ... ualcam.dts"
I can get a file "called dt-blob-dualcam.dts", It's at /hpm/pi/dt-blob-dualcam.dts
when I did the second step
[Usage: dtc [options] <input file>
Options: -[qI:O:o:V:d:R:S:p:a:fb:i:H:sW:E:@Ahv]
-q, --quiet
Quiet: -q suppress warnings, -qq errors, -qqq all
-I, --in-format <arg>
Input formats are:
dts - device tree source text
dtb - device tree blob
fs - /proc/device-tree style directory
-o, --out <arg>
Output file
-O, --out-format <arg>
Output formats are:
asm - assembler source
-V, --out-version <arg>
Blob version to produce, defaults to 17 (for dtb and asm output)
-d, --out-dependency <arg>
Output dependency file
-R, --reserve <arg>
Make space for <number> reserve map entries (for dtb and asm output)
-S, --space <arg>
Make the blob at least <bytes> long (extra space)
-p, --pad <arg>
Add padding to the blob of <bytes> long (extra space)
-a, --align <arg>
Make the blob align to the <bytes> (extra space)
-b, --boot-cpu <arg>
Set the physical boot cpu
-f, --force
Try to produce output even if the input tree has errors
-i, --include <arg>
Add a path to search for include files
-s, --sort
Sort nodes and properties before outputting (useful for comparing trees)
-H, --phandle <arg>
Valid phandle formats are:
legacy - "linux,phandle" properties only
epapr - "phandle" properties only
both - Both "linux,phandle" and "phandle" properties
-W, --warning <arg>
Enable/disable warnings (prefix with "no-")
-E, --error <arg>
Enable/disable errors (prefix with "no-")
-@, --symbols
Enable generation of symbols
-A, --auto-alias
Enable auto-alias of labels
-h, --help
Print this help and exit
-v, --version
Print version and exit
Error: missing files
/code]
