Flourishya
Compute module 3 (CM3) image
Tue Sep 25, 2018 10:46 am
Hi all,
Can someone kindly share the image for Raspberry Pi compute module 3 with user interface which I could boot from my 4GB EMMC?
Thanks in advance.
Andyroo
Re: Compute module 3 (CM3) image
Tue Sep 25, 2018 11:59 am
Have you seen this https://www.raspberrypi.org/documentati ... lashing.md
No disrespect to fellow forum members but who knows what’s in a binary file you get :o
Flourishya
Tue Sep 25, 2018 1:59 pm
I have already tried this procedure but the image is exceeding 4GB and if I try image which is less than 4GB then am not able to install UI.
Kindly share an image which is less than 4GB.
Andyroo
Tue Sep 25, 2018 5:56 pm
Strange - Have you seen this https://jumpnowtek.com/rpi/Working-with ... mpute.html
The result is very small:
[email protected]:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 3.5G 626M 2.7G 19% /
devtmpfs 458M 0 458M 0% /dev
tmpfs 462M 100K 462M 1% /run
tmpfs 462M 48K 462M 1% /var/volatile
You can then install LXDE as per https://raspberrypi.stackexchange.com/q ... on-raspbmc with ease if you want a GUI.
If that does not help maybe place an ad in the Wanted board?
Return to “Compute Module”
