RPI CM3 with I/O Board cannot use with ADAFRUIT Video converter module
Posted: Wed Aug 29, 2018 1:10 pm
Hello everyone, we are trying to connect the HDMI output of the CM3 I/O Board to a 5 inch 40 pin display trought Adafruit HDMI to TFT Decoder Breakouthttps://www.adafruit.com/product/2219 but if we configure raspbian /boot/config.txt file like Adafruit instruction, the display doesn't work, only show white backlight flickering.
We can use it with normal Raspberry pi 3 without any troubles and if we connect the I/O board to a standard PC monitor it works.
Does anyone had the same trouble?
Thanks a lot from Elia and BRIAN!
