eliottt
[SOLVED] CMIO 1.2 with CM 3
Wed Aug 29, 2018 11:55 am
I made a electronic board to use with CM3 but I took the wrong schematic source CMIO 1.2 instead of CMIO Rev 3.0.
I'm able to boot normally my raspberry but usb seems doesn't work in interface with a LAN9512.
When I want to boot from USB to mount the EMCC to my computer the raspberry boot normally.
I don't really see the reason of that after comparing the schematics, I think I miss something.
Thanks you for help.
Eliott.
aBUGSworstnightmare
Re: CMIO 1.2 with CM 3
Wed Aug 29, 2018 1:46 pm
eliottt wrote:Thanks you for help.
... and what is your question?
In case USB is not working there can be several issues, like incorrect routing, D+ swapped with D-, crosstalk/noise influence from on-board power sources etc.
One note: have you condidered power requirement of CM3 (higher, compared to CM1) when designing your board?
eliottt
Fri Aug 31, 2018 11:32 am
Thank you for the answer.
My question was what on the CMIO 1.2 schematic can make unusable USB on the CM3 board ?
I ordered an CM1 board and USB boot is okay my card is detected on windows as BCM,2708 Boot, so for me it's not an USB issue.
I have to check the normal boot, but I have to install first rasbian because the card is new.
I noted that the pin USB_OTGID is not pulled down on my card, does this pin could have an infludence on CM3 but not CM1 ?
About power requirement yes my power supply can deliver 2A at 5V but the sub stage 1.8V and 3V3 is designed for CM1, I didn't checked if there is any difference.
Regards,
Eliott.
eliottt
Mon Sep 03, 2018 9:06 am
my CM3 is now working with USB_OTGID pulled down as host usb configuration.
LAN also works !
Eliott.
Return to “Compute Module”
