demedeirosa
Determining via GPIO is the OS has fully shutdown?
Fri Aug 17, 2018 4:57 pm
Hi all,
Using a CM3L on a custom project. I currently have a supercap backup setup where I am monitoring a GPIO via a script, and shutting down immediately if the GPIO goes LOW. My current issue is that my supercap has a bit more energy than is required, and it keeps the 3.3V and 1.8V supplies on until the supercap is empty. This usually takes 5-10 seconds or so.
My backup IC has the ability to shutoff output power with a a digital input. Is there a way to have a GPIO on the Pi change state once the system is completely shutdown? I seem to vaguely recall that there may be something like this already implemented, but I cant seem to find any info on it.
So for clarity, I am looking for a pin state change, when the OS is fully shutdown. Basically something telling me that it is ok to completely remove power.
gsh
Re: Determining via GPIO is the OS has fully shutdown?
Mon Aug 20, 2018 8:01 am
gpio_restart and gpio_poweroff are built into the kernel so it should just be a matter of providing the right device tree elements with the right gpio description
Gordon Hollingworth PhD
PhilE
Mon Aug 20, 2018 8:34 am
An overlay to enable this feature already exists:
[email protected]:~$ dtoverlay -h gpio-poweroff
Info:   Drives a GPIO high or low on poweroff (including halt). Enabling this
        overlay will prevent the ability to boot by driving GPIO3 low.
Usage:  dtoverlay=gpio-poweroff,<param>=<val>
Params: gpiopin                 GPIO for signalling (default 26)
        active_low              Set if the power control device requires a
                                high->low transition to trigger a power-down.
                                Note that this will require the support of a
                                custom dt-blob.bin to prevent a power-down
                                during the boot process, and that a reboot
                                will also cause the pin to go low.
        input                   Set if the gpio pin should be configured as
                                an input.
        export                  Set to export the configured pin to sysfs
Return to “Compute Module”
