MWPau
CM3 eMMC boot delay
Sun Aug 05, 2018 9:23 am
Greetings all,
I'm trying to work out what's causing an approx 13sec delay after power-up of a CM3 on a Waveshare "IO Board Plus".
I'm booting from the CM3's eMMC, and monitoring start progress on the serial console.
After power-on, it takes approx 13sec before i see any output (linux kernel boot log) info on the console.
Does anyone know what causes this delay?
Thanks in advance!
John Westlake
Re: CM3 eMMC boot delay
Sun Aug 05, 2018 1:33 pm
A common issue for first time CM3 hardware developers - I'm betting you missed a pull-up resistor on the HDMI_SDA line :)
See this Thread:-
viewtopic.php?f=98&t=115095
MWPau
Sun Aug 05, 2018 3:15 pm
A 2.2k pull up to 3.3v seems to have done the trick.
Is there a recommended resistor value that should be used for this?
Thanks!
aBUGSworstnightmare
Mon Aug 06, 2018 10:19 am
https://www.raspberrypi.org/documentati ... CM_2p0.pdf
On page 12 you only find a note
f Requires external pull-up resistor to 5V as per HDMI spec
CMIO uses ESD5384 HDMI ESD protection
http://www.onsemi.com/pub/Collateral/ESD5384-D.PDF
Based on the parts spec:
R1, R2 Resistance min: 1575, typ: 1750, max: 1925
--> that's why I'm using 1k8 Ohms (to 3.3V as I don't have external HDMI connection). Anyway, your 2k2 Ohms pull-up should be fine.
John Westlake
Mon Aug 06, 2018 9:20 pm
Thanks!
If HDMI is not used, then 2K2 is OK, we use 10K...
Return to “Compute Module”
