When I check the frequency using "vcgencmd" , the command has two different arguments
1. Core
2. ARM
and with the above command, I am able to see two different frequencies. Can someone let me know what is exactly is a difference between two or why the difference is?
From cat /sys/devices/system/cpu/cpu0/cpufreq I could see the cpufreq for CPU0 and the current value is 600MHz . can this be operated below this value? is so at what minimum value I can go?
