InsertTitle
Query - Connecting a sensor via card edge connector. [solved]
Mon Jul 30, 2018 11:19 am
Trying to figure out how I an make my custom PCB more easily interchangeable should a sensor break I can easily swap out a new one. This would be a commercialised product but won't be released I suspect for at least another year or 2 as currently working on the 1st version and this for like version 4-5.0.
I've opted for a card edge connector to be mount onto the PCB using the EB43-S3R066FS https://www.mouser.co.uk/ProductDetail/ ... qWXtB1M%3d and to have a 6 finger connector on the PCB that the manufacturer will supply the sensor on (custom order).
Now the EB43 says it has 6 positions that will support the finger connector however upon reading into the datasheet it says it will have 6 positions on each side.
As far as I'm aware finger connectors on a PCB are 1 sided, so should I be worried about getting this edge connector or can I rest at ease by getting it and only connecting the finger connections that I actually need to the pins from the edge connector? Because out of the 6 finger connectors I only need to use 3 of them; however for stability and security I opted for 6 fingers.
scotty101
Re: Query - Connecting a sensor via card edge connector.
Mon Jul 30, 2018 11:25 am
What does this have to do with the Raspberry Pi?
Why not ask the manufacturer?
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
InsertTitle
Mon Jul 30, 2018 11:30 am
scotty101 wrote: What does this have to do with the Raspberry Pi?
I'm using the CM3 in the product.
I wanted to find out if my suspicions regarding PCB fingers & the card edge connector were correct. Don't need to check this with manufacturer as I already know its 6 positions on either side of the connector.
InsertTitle
Mon Jul 30, 2018 11:55 am
Disregard this thread now managed to answer own question after doing some research.
Mods can lock/delete thread.
RaTTuS
Contact: Twitter YouTube
Mon Jul 30, 2018 12:04 pm
just make it [solved] and put the answer at the end
Covfefe
Return to “Compute Module”
