opennandra
CM3 eMMC with u-boot not working
Wed Jul 11, 2018 9:55 am
I'm trying to use u-boot with CM3. I build it using yocto and board can boot but it looks like that u-boot cannot work with eMMC (commands for read/write fails). Anybody here have such thing working who can share path or ideas? Thanks.
opennandra
Re: CM3 eMMC with u-boot not working
Fri Jul 13, 2018 6:19 am
I build image for CM3 using meta-raspberrypi and it turns out that there was wrong configuration for u-boot. BTW it's still not clear is CM3 CPU 64 bit or not? According this page it is: https://www.raspberrypi.org/documentati ... /README.md Thanks
PhilE
Fri Jul 13, 2018 6:40 am
There should be no doubt - BCM2837 is a 64-bit capable SoC, but the standard Raspberry Pi kernel runs in 32-bit mode. While there are some nice aspects of going 64-bit, there is no clear performance benefit to justify supporting a third kernel variant.
Other distributions are available that are built for AArch64, should you wish to try one for yourself.
Fri Jul 13, 2018 6:46 am
Yes the ARMv8 CPU is 64bit AArch64:
https://en.wikipedia.org/wiki/ARM_architecture#ARMv8-A
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
opennandra
Fri Jul 13, 2018 7:22 am
OK thanks for info.
Return to “Compute Module”
