Omromis
Booting CM3 from memory stick
Wed Jul 04, 2018 11:40 am
Hello. Is it possible to run compute module 3 from memory stick as from SD card? I uploaded a raspbian image using an etcher and put the pendrive into the USB HOST connector on the IO Board V3.0. Is this situation possible at all? What do I have to make it work?
W. H. Heydt
Re: Booting CM3 from memory stick
Thu Jul 05, 2018 5:31 am
Maybe...but it will try to boot from the on-board flash module first. If you really want to boot from an external device, look at the CM3L.
gsh
Thu Jul 05, 2018 11:00 am
Yes this is possible, but there are a couple of things you need to do, first off you need to set the program_usb_boot_mode=1 bit in the otp (just add to config.txt and boot...) you should be able to do this over the USB device boot, using usbbootgui on a Raspberry Pi or our x86 release. You can just select 'custom application' and point it at a directory that contains bootcode.bin, start.elf and config.txt and it should correctly program the bit.
Then you need to make sure the otg_id pin is correctly pulled to enable host mode (i.e. drive to ground), noting that if you enable host boot mode then the otg_id is used to select between device mode and host mode (it needs to be a host to boot from mass storage). By default the OTG_ID pin has R12 which pulls it to ground for you, so I would suggest you remove this resistor and then use a jumper to switch it to host mode...
To make it then return to device boot mode you'll need to let the OTG_ID pin float (i.e. R12 will need to be removed to make it programmable after having set the usb_boot_mode bit...
Gordon Hollingworth PhD
Return to “Compute Module”
