njsss
Can CM3L be used as the same way as original pi?
Fri May 25, 2018 9:21 pm
Possible to make a customized io board with SD card, wifi and same 40-pin GPIOs, and running stock raspbian?
rzusman
Re: Can CM3L be used as the same way as original pi?
Sat May 26, 2018 2:59 am
I don’t see any reason why not.
ghans
Sat May 26, 2018 6:19 am
You might want to look into element14s Raspberry Pi customization service.
ghans
njsss
Sat May 26, 2018 6:08 pm
After a little bit search, it seems that it might be cheaper to customize Pi3 (eliminate ports, reduce size) rather than make a customized CM3 IO board + CM3L. Any thoughts?
rzusman
Sat May 26, 2018 9:27 pm
It really depends on the volume.
A CM-based system also allows you to tailor the carrier board to the exact shape needed, and add any special interfaces.
BudO
Tue May 29, 2018 7:43 pm
We developed a Proto Codec Board ("Hat") for the Pi 3 booting from an SD card. When we plug the same SD Card into a CM3 IO Board using the same Proto Codec connected to the same GPIO Points it does not work correctly. Any thoughts?
PhilE
Tue May 29, 2018 7:47 pm
@BudO Start a new topic. And you may want to, I dunno, give some details about how it doesn't work correctly?
njsss
Tue May 29, 2018 8:53 pm
@rzusman do you have a rough number on the estimation?
Return to “Compute Module”
