Bocana
Flashing the CM3 with Compute Module IO board
Wed May 09, 2018 12:31 pm
I would like to flash my RPI CM3 with a CM IO Board. I am following this tutorial : https://www.raspberrypi.org/documentati ... lashing.md
Whereas, when I'm connecting the Board to my PC, and making doing : sudo ./rpiboot . Nothing appends ... I have just this message : Waiting for BCM2835/6/7
I put the jumper J4 (USB Slave Boot Enable) to ENable, and I am using a Ubuntu on my PC.
Have you got any idea ?
Thanks !
PhilE
Re: Flashing the CM3 with Compute Module IO board
Wed May 09, 2018 2:11 pm
1. I assume the CMIO board is powered?
2. What does "lsusb" show on the PC?
3. Do you have a regular Raspberry Pi to use as a known good host for testing?
gsh
Wed May 09, 2018 3:00 pm
Are you sure you've got the PC plugged into the USB slave connection and power connected to power in? Do both the red and green LEDs come on and stay on?
Gordon
Gordon Hollingworth PhD
Return to “Compute Module”
