JudeDcoutho
How can I install a GUI for the Raspberry Pi Compute Module
Tue Apr 03, 2018 8:12 am
Ho can install the required packages so i can have GUI for the raspberry pi compute module ?
i tried installing the Xinit / Xserver-xorg but it was not successfull .
Re: GUI for the Raspberry Pi Compute Module
Tue Apr 03, 2018 9:59 am
Depends on Operating System you have installed :roll:
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
W. H. Heydt
Tue Apr 03, 2018 2:39 pm
It's likely (absent better data) that the problem here is that the CM and CM3 have "only" 4GB of eMMC flash on them. That isn't enough for a full Raspbian install.
There are a number of solutions... The simplest is to switch to the NEC "CM3-16", which is a custom, but generally available CM3 with 16GB of eMMC flash on it. Other solutions will require a carrier board set up for this situation. As much eMMC flash as desired can be put on the carrier board and a CM3L will boot from that. Alternatively, an SD slot can be put on the carrier and used as a boot device for a CM3L. Other alternatives are to set the boot from USB OTP bit and boot over the USB bus from ones choice of device. This would also work with a CM3 if the on-board eMMC flash doesn't have a bootable image.
And, by the bye, there is an entire forum here devoted to Compute Module issues. Detailed advice can probably be had by moving this thread there.
JudeDcoutho
Tue Apr 17, 2018 4:47 pm
Thank You will move the question to the CM3 discussion panel
mahjongg
Tue Apr 17, 2018 8:35 pm
is this a formal request to move this thread to the compute module section :?: :mrgreen:
Normally its done with the report button, but okay, as long as you don't start a second thread about the same subject.
Moving the thread to Compute Module.
Tue Apr 17, 2018 9:21 pm
Raspbian Lite, maybe ???
sudo apt-get update
sudo apt-get install --no-install-recommends lxde xorg raspberrypi-ui-mods rpi-chromium-mods
adieu
JudeDcoutho
Re: How can I install a GUI for the Raspberry Pi Compute Module
Sun Jul 22, 2018 5:28 am
The basic solution that worked for me was to install Rasbian Stretch Lite .
And carried out the normal installation of x-org ,xserver and everything went well with space to spare after all the intallation .
Return to “Compute Module”
