[CM3] HC-SR04 driver available?
Posted: Sun Feb 18, 2018 6:07 pm
by Killertechno
Hy guys, I would like to connect HC-SR04 sensor to my CM3 board (I want use character device as exercise, nor Python library or similar)
My OS: Raspbian GNU/Linux 8 (jessie)
Kernel: 4.14.18
Processor: BCM2709
My old HC-SR04 driver is not working (maybe changed something in kernel/Debian), I have already enabled device-tree through raspi-config.
I've found several kernel drivers for Raspberry, but I can't compile due it's giving me some errors ( error: unknown field ‘class_attrs’ specified in initializer).
Source is https://github.com/johannesthoma/linux-hc-sro4 but using other hc-sr04 kernel driver for Raspberry I still get similar errors.
Any working driver?
Thanks.
Re: [CM3] HC-SR04 driver available?
Posted: Fri Feb 23, 2018 12:37 am
by adasek
Hi, I encoutered a similar problem.
Solved it in https://github.com/adasek/linux-hc-sro4
My circuit: https://tutorials-raspberrypi.com/raspb ... r-hc-sr04/
Compilation
I compiled locally on Raspberry with kernel 4.14.20-v7+ - got kernel source using the guide using the guide https://raspberrypi.stackexchange.com/a/40419 (rpi-source program is the trick, don't forget to apt update, apt dist-upgrade and rpi-update before)
modified linux-hc-sro4 Makefile:
obj-m += hc-sro4.o
ARCH=arm
KERNEL_DIR=/lib/modules/`uname -r`/build
all:
        make -C $(KERNEL_DIR) M=$(PWD) modules ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE)
clean:
        make -C $(KERNEL_DIR) M=$(PWD) clean ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE)
Next steps
(maybe obvious but may help someone)
#inside cloned hc-sro4 with modified makefile
make
#hc-sro4.ko was created
#Load module on a startup:
 #copy into modules dir (or any subdirectory)
 sudo cp hc-sro4.ko /lib/modules/`uname -r`/
 #append into modules.order
 sudo echo hc-sro4.ko >> /lib/modules/`uname -r`/modules.order
 #Probe all modules
 sudo depmod -a
 #Set to startup
 sudo echo "hc-sro4" >> /etc/modules
#One time load of a module
sudo modprobe hc-sro4
#should return something
lsmod | grep hc_sro4
#Creating a sensor
sudo echo "18 23 3000" > /sys/class/distance-sensor/configure
#change 18 - gpio trigger, 23 - gpio echo
#Measuring
cat /sys/class/distance-sensor/distance_18_23/measure
