sapnarazdan
Compute Module not booting
Tue Feb 06, 2018 4:25 am
My Compute module 3 lite is not booting up, although the LEDs on Compute I/O board are glowing. I am using it for the first time.
Please refer Page 4 of schematic diagram of Compute Module board, it says that "BMC2837 will fail to boot from SD if EMMC_DISABLE_IN is low". how to make it high.
Also we tried the following steps : refer attached link
https://www.raspberrypi.org/documentati ... lashing.md
Apart from it we tried by using noobs : https://www.raspberrypi.org/downloads/noobs/.
Looking forward to solution.
ethanol100
Re: Compute Module not booting
Wed Feb 07, 2018 11:05 am
Did you set the J4 to DIS on the IO board? Do you have a normal Raspberry Pi to check if it would boot from your SD card?
sapnarazdan
Fri Mar 23, 2018 10:15 am
Our response is as below:
1. Did you set the J4 to DIS on the board? : Yes
2. Did you have a normal Raspberry Pi to check if it would boot from your SD Card? - Yes. We have RPi 3 Version 1.2 which boots with the help of SD card.
Return to “Compute Module”
Who is online
Users browsing this forum: gsh, nikoku and 6 guests
