carlo.antinarella
Setting GPIO alternate functions by modifying the device tree
Mon Jan 29, 2018 8:02 am
Hi everyone,
I'm new to Raspberry. I have a CM3, and I would like to switch to alternate function number 3 (I'm referring to the official datasheet) for GPIO pins 31 and 32. It is my necessity to have these pins operating that way from the boot on, so I decided to modify the device tree source adding the following code to the root node:
videocore {
		pins_cm3 { // Pi 3 CM3
			pin_config {
				[email protected] {
					polarity = "active_high";
					termination = "pull_down";
					startup_state = "inactive";
					function = "input";
				}; // pin
				[email protected] { function = "uart0"; termination = "no_pulling"; drive_strength_mA = < 8 >; }; // TX uart0
				[email protected] { function = "uart0"; termination = "pull_up"; drive_strength_mA = < 8 >; };
			}; // pin_config
		}; // pins
after compiling with
sudo dtc -I dts -O dtb -o /boot/dt-blob.dtc
I couldn't see any changes in the GPIO alternate functions using
sudo raspi-gpio get
Maybe I'm missing something, but I can't figure out why this is not working.
6by9
Re: Setting GPIO alternate functions by modifying the device tree
Mon Jan 29, 2018 9:57 am
The file needs to be /boot/dt-blob.bin, not .dtc.
PhilE
Mon Jan 29, 2018 9:58 am
The dt-blob (it's not really Device Tree) file must be called "dt-blob.bin" and copied into the root of the SD card (/boot) alongside the other boot files. Also, pin 31 isn't TXD0 - it's RTS0. I think you want 32 and 33.
There is now an easier way to achieve the same effect, and that is to use the new "uart0" overlay, but that requires a very recent firmware.
Return to “Compute Module”
