MaNu_MaLoNe
Both UARTs enabled + serial (Linux) console on UART1. How to?
Wed Jan 17, 2018 1:53 pm
Few months ago I designed a circuit based on CM3L. It was devised to use both UARTs on GPIOs 14/15 and 32/33 (both pairs can be UART0 or UART1). Now my client is using UARTO on GPIOs 14/15 for communicating with a microcontroller. Now they are asking me to enable the sencond UART that was placed with the purpose of serving as serial debug port (Linux console).
Is it possible to use UART1 as Linux console instead of UART0? If so... What should I do to remap UARTs in GPIOs, enable both UARTs, enable Linux console and route it to UART1? If possible all done in device tree and "/boot" config files better than using raspi-config and gpio utility.
Thanks in advance!
Manuel.
PhilE
Re: Both UARTs enabled + serial (Linux) console on UART1. How to?
Wed Jan 17, 2018 9:43 pm
You can enable UART1 and map it to GPIOs 32 and 33 by adding the following to /boot/config.txt:
dtoverlay=uart1,txd1_pin=32,rxd1_pin=33
To create a linux console on UART1 (ttyS0), add "console=ttyS0,115200" to /boot/cmdline.txt.
MaNu_MaLoNe
Wed Jan 24, 2018 6:35 pm
Thanks a lot PhilE!
It worked. The only issue is that I had to place core_freq at 250Mhz in order to make the UART work with the correct baudrate.
Manuel.
Killertechno
Wed Feb 21, 2018 6:06 pm
Where?
PhilE
Wed Feb 21, 2018 6:34 pm
core_freq=250 in config.txt.
Return to “Compute Module”
