WisePi
USB OTG in CM3
Wed Jan 10, 2018 6:14 pm
Has anyone been able to use the USB OTG on the RPi CM3? I'm following https://gist.github.com/gbaman/50b6cca61dd1c3f88f41 without success. Also, I noticed that when I connect a host computer via USB OTG to the RPi port USB Slave, the Linux terminal becomes unresponsive. This happens with the jumper in both EN and Disable positions.
Any help would be greatly appreciated.
Return to “Compute Module”
