picandies
Getting CM3L running--trouble
Fri Nov 17, 2017 8:45 am
I've been using the RPI3 for a while with no issue, but need a small form factor
I bought the CM3L & the I/O expander board.
I put downloaded & unzipped NOOBS onto the SD card & installed into the board & hooked up my HDMI monitor (which I've used with the RPI3).
Applying power, nothing happens (monitor shows a black screen)
Do I need to move some jumpers to make it work?
ANSWER--I got it going fine, I was just having a cabling issue!!
Also, the jumpers from the factory were in the proper spot
PhilE
Re: Getting CM3L running--trouble
Fri Nov 17, 2017 9:10 am
Make sure that jumper J4 (next to the USB slave connector) is set to BOOT ENABLE (not USB SLAVE).
Return to “Compute Module”
