picandies
adding wifi to cm3l/io board setup
Tue Nov 14, 2017 4:41 pm
Using CM3 lite & the standard compute I/O board...found out it doesn't have wifi...so no internet. What is easiest way to add wifi & set up, so I can access the internet to do sudo update & upgrade, and install other packages?
Re: adding wifi to cm3l/io board setup
Tue Nov 14, 2017 5:17 pm
USB Wireless Adaptor ???
https://www.raspberrypi.org/products/ra ... fi-dongle/
Adieu
picandies
Tue Nov 14, 2017 6:23 pm
do you just plug in & it starts working (no files/adjust needed)?
Is this a special item for the PI, or would any such device from Microcenter or Walmart plug & play?
Tue Nov 14, 2017 6:44 pm
Well the one I linked to is the Official Item so yes it is fully supported in Raspbian Operating System.
There is a list here of some other compatible USB Wireless:
https://elinux.org/RPi_USB_Wi-Fi_Adapters
Adieu
Return to “Compute Module”
Who is online
Users browsing this forum: No registered users and 5 guests
