roshnee_kishore
[SOLVED] Cameras not detected! vcgencmd get_camera outputs supported=2, detected=0 in cm3 with emmc flash
Mon Nov 13, 2017 12:07 pm
Hi,I am new to raspberry pi compute module.
I was working with the cm3 lite before this with a full desktop version installed and hence had no problems with the camera modules.
Since my cm3 lite got short i have to use the cm3 with flash memory which has the jessie lite version installed.
I did the procedure in the rpi in order to support dual cameras and hopefully succeeded with the blob files. I have connected the gpio pins for the camera setup as given in the tutorial
https://www.raspberrypi.org/documentati ... -camera.md
I reboot the pi and i run the command
vcgencmd version
which outputs
Nov  3 2017 17:05:40
Copyright (c) 2012 Broadcom
version 1bcf9152e3b2ab5c67dcb9c7c1f6d9256d9a6f38 (clean) (release)
then, i ran
vcgencmd get_camera
which outputs
shows that the blob files are right.
To check the gpio pins i ran
sudo raspi-gpio get
and found that the raspi-gpio package was not installed as I was using the lite version. Then I istalled it using
sudo apt-install raspi-gpio
And now,
sudo raspi-gpio get
outputs
BANK0 (GPIO 0 to 27):
  GPIO 00: level=0 fsel=0 alt=  func=INPUT
  GPIO 01: level=0 fsel=0 alt=  func=INPUT
  GPIO 02: level=0 fsel=1 alt=  func=OUTPUT
  GPIO 03: level=0 fsel=1 alt=  func=OUTPUT
  GPIO 04: level=0 fsel=0 alt=  func=INPUT
  GPIO 05: level=0 fsel=0 alt=  func=INPUT
  GPIO 06: level=0 fsel=0 alt=  func=INPUT
  GPIO 07: level=0 fsel=0 alt=  func=INPUT
  GPIO 08: level=0 fsel=0 alt=  func=INPUT
  GPIO 09: level=0 fsel=0 alt=  func=INPUT
  GPIO 10: level=0 fsel=0 alt=  func=INPUT
  GPIO 11: level=0 fsel=0 alt=  func=INPUT
  GPIO 12: level=0 fsel=0 alt=  func=INPUT
  GPIO 13: level=0 fsel=0 alt=  func=INPUT
  GPIO 14: level=0 fsel=4 alt=0 func=TXD0
  GPIO 15: level=0 fsel=4 alt=0 func=RXD0
  GPIO 16: level=0 fsel=0 alt=  func=INPUT
  GPIO 17: level=0 fsel=0 alt=  func=INPUT
  GPIO 18: level=0 fsel=0 alt=  func=INPUT
  GPIO 19: level=0 fsel=0 alt=  func=INPUT
  GPIO 20: level=0 fsel=0 alt=  func=INPUT
  GPIO 21: level=0 fsel=0 alt=  func=INPUT
  GPIO 22: level=0 fsel=0 alt=  func=INPUT
  GPIO 23: level=0 fsel=0 alt=  func=INPUT
  GPIO 24: level=0 fsel=0 alt=  func=INPUT
  GPIO 25: level=0 fsel=0 alt=  func=INPUT
  GPIO 26: level=0 fsel=0 alt=  func=INPUT
  GPIO 27: level=0 fsel=0 alt=  func=INPUT
BANK1 (GPIO 28 to 45):
  GPIO 28: level=0 fsel=4 alt=0 func=SDA0
  GPIO 29: level=0 fsel=4 alt=0 func=SCL0
  GPIO 30: level=0 fsel=1 alt=  func=OUTPUT
  GPIO 31: level=0 fsel=1 alt=  func=OUTPUT
  GPIO 32: level=0 fsel=0 alt=  func=INPUT
  GPIO 33: level=0 fsel=0 alt=  func=INPUT
  GPIO 34: level=0 fsel=0 alt=  func=INPUT
  GPIO 35: level=0 fsel=0 alt=  func=INPUT
  GPIO 36: level=0 fsel=0 alt=  func=INPUT
  GPIO 37: level=0 fsel=0 alt=  func=INPUT
  GPIO 38: level=0 fsel=0 alt=  func=INPUT
  GPIO 39: level=0 fsel=0 alt=  func=INPUT
  GPIO 40: level=0 fsel=0 alt=  func=INPUT
  GPIO 41: level=0 fsel=0 alt=  func=INPUT
  GPIO 42: level=0 fsel=0 alt=  func=INPUT
  GPIO 43: level=0 fsel=0 alt=  func=INPUT
  GPIO 44: level=0 fsel=0 alt=  func=INPUT
  GPIO 45: level=0 fsel=0 alt=  func=INPUT
BANK2 (GPIO 46 to 53):
  GPIO 46: level=1 fsel=0 alt=  func=INPUT
  GPIO 47: level=1 fsel=0 alt=  func=INPUT
  GPIO 48: level=0 fsel=4 alt=0 func=SD0_CLK
  GPIO 49: level=1 fsel=4 alt=0 func=SD0_CMD
  GPIO 50: level=1 fsel=4 alt=0 func=SD0_DAT0
  GPIO 51: level=1 fsel=4 alt=0 func=SD0_DAT1
  GPIO 52: level=1 fsel=4 alt=0 func=SD0_DAT2
  GPIO 53: level=1 fsel=4 alt=0 func=SD0_DAT3
and the my dt-blob-dualcam.dts file consists of the following,
dts-v1/;
  videocore {
    pins_cm {
      pin_config {
        [email protected] {
          polarity = "active_high";
          termination = "pull_down";
          startup_state = "inactive";
          function = "input";
        }; // pin
        // BANK 0 - USER GPIO //
        [email protected]  { function = "input";   termination = "pull_up";    }; // GPU WILL USE THIS PIN FOR CAMERA 0 I2C0 SDA
        [email protected]  { function = "input";   termination = "pull_up";    }; // GPU WILL USE THIS PIN FOR CAMERA 0 I2C0 SCL
        [email protected]  { function = "output";  termination = "no_pulling"; }; // GPU WILL USE THIS PIN FOR CAMERA 0 LED
        [email protected]  { function = "output";  termination = "no_pulling"; }; // GPU WILL USE THIS PIN FOR CAMERA 0 SHUTDOWN
        [email protected]  { function = "input";   termination = "pull_up";    }; // DEFAULT STATE
        [email protected]  { function = "input";   termination = "pull_down";  }; // DEFAULT STATE
// TO ENABLE UART0 UNCOMMENT THESE 2 LINES:
//       [email protected] { function = "uart0";   termination = "no_pulling"; }; // UART0 TX
//       [email protected] { function = "uart0";   termination = "pull_up";    }; // UART0 RX
// AND COMMENT OUT/REMOVE THESE 2 LINES:
        // BANK 1 - USER GPIO//
        [email protected] { function = "input";   termination = "pull_up";    }; // GPU WILL USE THIS PIN FOR CAMERA 1 I2C0 SDA
        [email protected] { function = "input";   termination = "pull_up";    }; // GPU WILL USE THIS PIN FOR CAMERA 1 I2C0 SCL
        [email protected] { function = "output";  termination = "no_pulling"; }; // GPU WILL USE THIS PIN FOR CAMERA 1 LED
        [email protected] { function = "output";  termination = "no_pulling"; }; // GPU WILL USE THIS PIN FOR CAMERA 1 SHUTDOWN
        [email protected] { function = "input";   termination = "pull_down";  }; // DEFAULT STATE WAS INPUT NO PULL
        // BANK 2 - DON'T TOUCH UNLESS YOU KNOW WHAT YOU'RE DOING //
        [email protected] { function = "input";   termination = "no_pulling"; drive_strength_mA = <8>; polarity = "active_high"; }; // HPD_N
        [email protected] { function = "output";  termination = "no_pulling"; drive_strength_mA = <8>; polarity = "active_low"; startup_state = "active"$
        [email protected] { function = "sdcard";  termination = "pull_up";    drive_strength_mA = <8>; }; // SD CLK
        [email protected] { function = "sdcard";  termination = "pull_up";    drive_strength_mA = <8>; }; // SD CMD
        [email protected] { function = "sdcard";  termination = "pull_up";    drive_strength_mA = <8>; }; // SD D0
[email protected] { function = "sdcard";  termination = "pull_up";    drive_strength_mA = <8>; }; // SD D1
        [email protected] { function = "sdcard";  termination = "pull_up";    drive_strength_mA = <8>; }; // SD D2
        [email protected] { function = "sdcard";  termination = "pull_up";    drive_strength_mA = <8>; }; // SD D3
      }; // pin_config
      pin_defines {
        [email protected]_ENABLE {
           type = "internal";
           number = <47>;
        [email protected]_CAMERAS {
          type = "internal";
          number = <2>;
        [email protected]_0_LED {
          type = "internal";
          number = <2>;
[email protected]_0_SHUTDOWN {
          type = "internal";
          number = <3>;
        [email protected]_0_UNICAM_PORT {
          type = "internal";
          number = <1>;
        [email protected]_0_I2C_PORT {
          type = "internal";
          number = <0>;
        [email protected]_0_SDA_PIN {
          type = "internal";
          number = <0>;
        [email protected]_0_SCL_PIN {
          type = "internal";
          number = <1>;
[email protected]_1_LED {
          type = "internal";
          number = <30>;
        [email protected]_1_SHUTDOWN {
          type = "internal";
          number = <31>;
        [email protected]_1_UNICAM_PORT {
          type = "internal";
          number = <0>;
        [email protected]_1_I2C_PORT {
          type = "internal";
          number = <0>;
        [email protected]_1_SDA_PIN {
          type = "internal";
          number = <28>;
[email protected]_1_SCL_PIN {
          type = "internal";
          number = <29>;
      }; // pin_defines
    }; // pins_cm
    pins_cm3 {
      pin_config {
        [email protected] {
          function = "input";
        }; // pin
[email protected]  { function = "input";  termination = "pull_up";    }; // CAMERA 0 I2C0 SDA
        [email protected]  { function = "input";  termination = "pull_up";    }; // CAMERA 0 I2C0 SCL
        [email protected]  { function = "output"; termination = "no_pulling"; }; // CAMERA 0 LED
        [email protected]  { function = "output"; termination = "no_pulling"; }; // CAMERA 0 SHUTDOWN
        [email protected] { function = "uart0";  termination = "no_pulling"; drive_strength_mA = < 8 >; }; // TX uart0
        [email protected] { function = "uart0";  termination = "pull_up"; drive_strength_mA = < 8 >; }; // RX uart0
        [email protected] { function = "input";  termination = "pull_up";    }; // CAMERA 1 I2C0 SDA
        [email protected] { function = "input";  termination = "pull_up";    }; // CAMERA 1 I2C0 SCL
        [email protected] { function = "output"; termination = "no_pulling"; }; // CAMERA 1 LED
        [email protected] { function = "output"; termination = "no_pulling"; }; // CAMERA 1 SHUTDOWN
        [email protected] { function = "input";  termination = "pull_up";    }; // SMPS_SCL
        [email protected] { function = "input";  termination = "pull_up";    }; // SMPS_SDA
        [email protected] { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD CLK
        [email protected] { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD CMD
        [email protected] { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD D0
        [email protected] { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD D1
        [email protected] { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD D2
        [email protected] { function = "sdcard"; termination = "pull_up";    drive_strength_mA = < 8 >; }; // SD D3
        [email protected] { function = "input";  termination = "no_pulling"; polarity = "active_low"; }; // Hotplug
        [email protected] { function = "output"; termination = "no_pulling"; polarity = "active_low"; }; // EMMC_ENABLE_N
}; // pin_config
      pin_defines {
        [email protected]_CONTROL_ATTACHED {
           type = "external";
           number = <0>;
           type = "external";
           number = <1>;
        [email protected]_LOW {
           type = "absent";
        [email protected]_DISK_ACTIVITY {
           type = "absent";
        [email protected]_RUN {
           type = "absent";
[email protected]_SDA {
           type = "internal";
           number = <46>;
        [email protected]_SCL {
           type = "internal";
           number = <47>;
        [email protected]_CLK {
           type = "absent";
        [email protected]_LPO_CLK {
           type = "absent";
        [email protected]_LIMIT_1A2 {
           type = "absent";
        [email protected]_1V8_SEL {
           type = "absent";
[email protected] {
           type = "absent";
        [email protected] {
           type = "absent";
        [email protected]_MODE {
           type = "absent";
        [email protected]_CARD_DETECT {
           type = "absent";
           type = "absent";
           type = "absent";
type = "internal";
          number = <2>;
          type = "internal";
          number = <2>;
          type = "internal";
          number = <3>;
          type = "internal";
          number = <1>;
          type = "internal";
          number = <0>;
  type = "internal";
          number = <0>;
          type = "internal";
          number = <1>;
          type = "internal";
          number = <30>;
          type = "internal";
          number = <31>;
          type = "internal";
          number = <0>;
type = "internal";
          number = <0>;
          type = "internal";
          number = <28>;
          type = "internal";
          number = <29>;
      }; // pin_defines
    }; // pins_cm3
In my
/boot/config.txt
file, i set the dt_param=12C=on to off mode.
I tried rebooting my pi but still couldn't figure out the problem as it still persists.
I found out some i2c issue with cm3 with emmc flash as in the given link,
https://www.element14.com/community/thr ... hread=true
but, could this be a problem?
Could somebody please help? :(
Last edited by roshnee_kishore on Mon Nov 20, 2017 9:54 am, edited 1 time in total.
6by9
Re: Cameras not detected! vcgencmd get_camera outputs supported=2, detected=0 in cm3 with emmc flash
Wed Nov 15, 2017 11:06 am
Nothing obviously wrong in your description, other than presumably a typo as it should be
dt_param=i2c=off
or more precisely
dt_param=i2c_arm=off
edit: This is wrong - see correction below!
Your raspi-gpio output looks correct anyway.
External pullups shouldn't be needed on the I2C lines - certainly it worked for me without.
Some steps for manually debugging the I2C connectivity - viewtopic.php?f=98&t=89876&start=75#p1038279
And make sure you're using the CMIO-CAMERA boards for both cameras, not the CMIO-DISPLAY board.
Please don't send PMs asking for support - use the forum.
PhilE
Wed Nov 15, 2017 11:22 am
Ahem - that should say:
dtparam=i2c_arm=off
(no underscores in dtparam)
6by9
Wed Nov 15, 2017 12:36 pm
dtparam=i2c_arm=off
Doh! Always read what is actually there, not what you think is there. Thank you.
Tangent: Reminds me of a bug that I introduced (unintentionally I hasten to add):
if (condition1)
   //This shouldn't happen, so let's clean up where it has an impact
   for(i=1; i<loop_count; i++)
       if (condition2);
          do_something_significant(i);
That took a while to see the error. Fortunately it was the only bit of code that had the potential to cause the symptoms being seen, so it was a case of staring at it. Unfortunately do_something_significant was very obvious to the customer and caused them to shout rather loudly!
It didn't help that condition2 was quite long, so it went off the end of the line (perhaps 80 characters per line isn't so daft sometimes).
I wasn't allowed to live it down for a while :(
PhilE
Wed Nov 15, 2017 12:39 pm
That's unfair - you'd think the compiler could warn about empty statements.
6by9
Wed Nov 15, 2017 12:49 pm
This was Borland C++ 3.1, so a fair while ago (~2003 at a guess). Modern gcc probably will complain.
And blaming the compiler didn't wash with the customer.
gsh
Wed Nov 15, 2017 2:45 pm
Still not as bad as the guy who changed an installation script so that when you update you could tell it what the old directory was:
old:
sudo rm -rf /usr/company/software/
new:
sudo rm -rf $(OLD_INSTALL)/
The customer then called up to complain that they ran the install script without the OLD_INSTALL defined on the server, this had all the client computer's disks mounted as well... This was inside a TV distribution centre where they had something like 200 servers all streaming the channels. Took a couple of weeks to get the data back!
Gordon Hollingworth PhD
roshnee_kishore
Mon Nov 20, 2017 9:44 am
Well, thanks all for trying to help me out :) Yes, i set the dtparam=i2c_arm=off.
The problem was that the gpio pins were powered externally and the jumper pins in j3 were put up in the wrong way which would actually power it up. Since the gpio pins were not powered the cameras were not being detected nor the inputs sent to the motor drivers. I also tried to communicate manually to the cameras by doing the following as suggested in another thread with similar issue (viewtopic.php?t=174347&p=1117869).
- Add "dtparam=i2c_arm" to /boot/config.txt and reboot.
- Load the i2c-dev module (if you haven't already).
- Install i2c-tools, and raspi-gpio.
- Connect CD1_[SDA|SCL] to pins 2&3, and CAM1_IO[0|1] to 4&5.
- "sudo raspi-gpio set 4 op dh"
- "sudo raspi-gpio set 5 op dh"
- "sudo raspi-gpio get" and check that 2&3 are SDA1 and SCL1, and 4&5 are outputs.
- "sudo i2c-detect -y 1" you should see a device (the camera) on address 0x10.
- Repeat but connecting CD0_[SDA|SCL] to pins 2&3, and CAM0_IO[0|1] to 4&5.
If that all checks out, then put the wiring back as the GPU should be able to see the cameras too.
I wasn't able to get the address of the camera device. In fact it was all blank.
All trouble shooting techniques helped me detect that everything was fine except that the gpio pins (hardware) was not working right.
And now that the jumpers are placed correctly, the gpio pins are powered and it works :D
6by9
Mon Nov 20, 2017 11:29 am
<snip>
Thanks for the returning to report your findings.
I'd forgotten that the voltage to the GPIO banks could be changed on the CMIO - probably one worth adding to the docs. The I2C may still work, but the GPIOs are unlikely to.
Return to “Compute Module”
Who is online
Users browsing this forum: JBDynamics and 2 guests
