Aidos
I2C0 on CM3
Fri Sep 15, 2017 4:46 pm
Hi all,
I want use CM3 with Raspberry 7" LCD.
My question is: which GPIO should I use for SCL0 and SDA0 signals?
SCL1 is at GPIO3 and SDA1 is at GPIO2 normally, where are SCL0 and SDA0 normally? (when I use Pi Model A+ the LCD works with standard Raspbian).
In other words I want know which are the GPIO used on Pi Model A+ for SCL0 and SDA0.
Thank you!
ShiftPlusOne
Re: I2C0 on CM3
Fri Sep 15, 2017 5:44 pm
Aidos wrote: In other words I want know which are the GPIO used on Pi Model A+ for SCL0 and SDA0.
https://github.com/raspberrypi/firmware ... b.dts#L571
Re: I2C0 on CM3
Fri Sep 15, 2017 6:59 pm
For the A+ I would look at https://pinout.xyz
I2C0 SDA is GPIO 0 on pin 27 (ID_SD) and I2C0 SCL is GPIO 1 on pin 28 (ID_SC)
6by9
Re: I2C0 on CM3
Fri Sep 15, 2017 9:19 pm
Why not read the documentation? https://www.raspberrypi.org/documentati ... display.md
The GPIO usage on an A+ is pretty irrelevant to the CM. If you're really bothered, then it's GPIOs 28&29 as documented in the dt-blob.dts that ShiftPlusOne linked to.
Please don't send PMs asking for support - use the forum.
Aidos
Re: I2C0 on CM3
Sat Sep 16, 2017 7:53 am
Hi all,
Thank you for your reply, now I understand and it is more clear.
Return to “Compute Module”
Who is online
Users browsing this forum: Hellonity and 4 guests
