felipeleonicm
CM3 not detected by PC anymore!
Fri Sep 01, 2017 4:03 am
Hi!
I've designed a custom carrier board to be used with CM3, and it worked to flash the EMMC the first time, no problems.
The boot circuit is the same as the CMIO.
Now I would like to erase the flash and load other image, but when I set the jumper to enable the USB boot, same as if doing in the CMIO, the PC don't detect the device, and the CM3 boot normally. Even if I force the emmc_disable_n to GND by connecting it directly, I can't get the board detected by USB.
My host machine is Window 10, I don't think this is a problem, since I flashed the board in the same PC the first time.
Does anyone have this issue?
Felipe
PhilE
Re: CM3 not detected by PC anymore!
Fri Sep 01, 2017 9:39 am
Have you tried with the standard CMIO board?
felipeleonicm
Fri Sep 01, 2017 1:02 pm
I don't have the CMIO here :cry:
felipeleonicm
Sat Sep 02, 2017 7:41 pm
Solved. Problem was the MOSFETs I used to control the boot (USB/EMMC), the threshold voltage was a bit high than 1.8V. Replaced the transistors, and my board is working fine.
Rgds
Return to “Compute Module”
Who is online
Users browsing this forum: No registered users and 5 guests
