WiFi chip for Compute Module 3
Posted: Sun May 14, 2017 6:07 am
by pderocco
I'm thinking about using a CM3 in a project, but it needs WiFi. Apparently, the RPi 3B has a BCM43143 WiFi chip, but this doesn't appear to be readily available in modest quantities. And it is probably overkill, since I don't need an FM receiver, and I probably won't need Bluetooth. So what's the easiest WiFi chip with an SDIO interface that will work with a minimum of bother with the CM3? I'll probably be using Yocto to build a custom Linux, although any chip that works with Raspbian should be okay.
Re: WiFi chip for Compute Module 3
Posted: Mon May 22, 2017 7:24 pm
by yaheath
I can tell you one to avoid (at least for now). I've been trying to get an ATWILC1000 module working, but the driver support isn't there yet. There's a wilc1000 driver in drivers/staging but I wasn't able to get it to work (though it's being actively updated in the staging-next git repo). There's also an out-of-tree version published by Atmel but it doesn't build in 4.4 or 4.9.
I'll probably kick that one to the curb and look for something else.
One possibility is a USB based Wifi adapter. Since I plan on having a USB hub chip on my carrier board anyway I'll add a type-A jack and plug in one of the off-the-shelf tiny USB Wifi dongles.
Posted: Wed Oct 18, 2017 8:24 pm
by mseth
BUMP
Has anyone had any success finding a good option for this? Maybe something that also includes Bluetooth 4.0 (combo chip)
Posted: Wed Nov 15, 2017 3:07 pm
by ifarkas
Make it Bluetooth 5 LE + Wi-Fi with QCA4020 from Qualcomm.
Posted: Tue Nov 21, 2017 8:15 pm
by InsertTitle
Here's some good news for you I ended up looking into this for my own project and I came across the ESP-WROOM-32.
I've managed to fabricate the package/footprint part on Eagle if you're using eagle then I'll happily supply it for you to use.
Below is the schematic I did for mine.
You can power it using 3.3V or via a 5V to 3.3V convertor which is the design on the right hand side.
Connect CTS to GPIO39 & RTS to GPIO38 these are your data flow control pins should you wish to tell the device that you'd like to send/receive data from the pi/esp32
Connect RXD0 to GPIO15 & TXD0 to GPIO14 this is your UART Serial which connects directly into the CM3 as there is no need for a UART to USB Convertor atleast for my project I didn't need to use it and it simplifies the build down alot. However you're welcome to use one. The chip that is used for converting to USB is CP2102-QFN-P28. I've also made a footprint/package for this on eagle as well.
Posted: Fri Dec 15, 2017 10:47 am
by jrychter
I've had good experiences with TI WiLink chips, connected via SDIO. They exist in the form of pre-certified modules from a number of vendors (I used a Jorjin WG7831DELF). WiLink8 chips will do WiFi and Bluetooth, in various bands, depending on the specific option you choose.
TI supplies Linux drivers, which work.
Posted: Fri Mar 02, 2018 4:32 pm
by fishtrousers
Hi jrychter,
The module you suggested sounds like what I'm looking for but I'm struggling to find the drivers. Can you point me at them? Thanks!
Posted: Mon Apr 23, 2018 9:16 pm
by mkirk
Does anyone know the interfaces (port pins) on the Pi 3B BCM2837 SoC for the Wifi/BT chip CYW43438 (was BCM43438)?
The part is CYW43438 (now Cypress) datasheet http://www.cypress.com/file/298076/download
and part is available from US distributors Arrow, DigiKey and Mouser.
So can this be wired to the CM3 to match the Pi3B? Is there a reference design/schematic?
I understand that this would require US FCC Part 15 certification for the RF transmitter.
Posted: Thu Apr 26, 2018 8:53 pm
by John Westlake
I understand it uses a UART channel (for BT) and the secondary SDIO Card interface
I believe these are the I/O pins related to the WiFi / BT on the RPi3
pin@p14 { function = "uart0"; termination = "no_pulling"; drive_strength_mA = < 8 >; }; // TX uart0
pin@p15 { function = "uart0"; termination = "pull_up"; drive_strength_mA = < 8 >; }; // RX uart0
pin@p34 { function = "input"; termination = "pull_up"; drive_strength_mA = < 8 >; };
pin@p35 { function = "input"; termination = "pull_up"; drive_strength_mA = < 8 >; };
pin@p36 { function = "input"; termination = "pull_up"; drive_strength_mA = < 8 >; };
pin@p37 { function = "input"; termination = "pull_up"; drive_strength_mA = < 8 >; };
pin@p38 { function = "input"; termination = "pull_up"; drive_strength_mA = < 8 >; };
pin@p39 { function = "input"; termination = "pull_up"; drive_strength_mA = < 8 >; };
pin@p43 { function = "gp_clk"; termination = "pull_down"; }; // WIFI_CLK - Wifi 32kHz output
I have no direct experience - but this seems an educated guess - atleast a place to start.
Edit:-
Out of interest I've just probed a RPi3 PCB I have here and can confirm the above + an undocumented BT PCM Audio interface to the SoC
https://www.dropbox.com/s/bvxiws83xvy3t ... s.JPG?dl=0
I've highlighted the relent connections + note the x4 extra BT PCM audiopath connections (not required for WiFi / BT).
There might be secondary connections such as Reset / PowerDown... I cannot be sure, but these are the main SoC interface connections.
Posted: Fri Apr 27, 2018 8:59 am
by adun
We discussed this also here Which Wifi/Bluetooth chip does the RPi 3 model B integrates?
Soc:
GPIO 32-33 UART0 for BT
GPIO 34-38 SD1 for Wifi
GPIO 42 GPCLK1 for Ethernet 25MHz output
GPIO 43 GPCLK2 for Wifi 32kHz output
Port Expander
GPIO 128 BT_ON
GPIO 129 WL_ON
Posted: Fri Apr 27, 2018 4:34 pm
by mkirk
Thanks to all for the great information!
Posted: Sat Oct 13, 2018 12:43 am
by JBDynamics
I read this thread and after much further research, I decided to use a Ti WiLink8 chipset. The Jorjin WG7831DELF module is no longer available for purchase in the USA, so I looked on Ti's website, and found a few other similar modules. I decided to use a Laird LSR TiWi-BLE module, part number 450-0064R (I get them on Tape and reel), it is a Ti WiLink 8 SiP on a board with gold fingers and a U.FL connector for the antenna. It has full FCC certification, and should not require additional FCC testing if paired with one of two antennas sold by Laird (part numbers 001-0010 for a 2dB IP67 waterproof 50Ω impedance antenna and 001-0001 for a non-waterproof 2dB 50Ω impedance antenna). I can say that the Ti WiLink8 Kernel module can cross-compile for ARMv8 with Raspbian Kernel v.4.14.71. You need to supply a 32.768kHz clock signal, and all IO and power needs to be 1.8V except for VBAT. I am using a Ti TXB0108PWR voltage level translator to downshift the 3.3V IO to 1.8V, the other option is to supply 1.8V to one of the GPIO VREF's and run IO at 1.8V. WLAN interfaces over SDIO on SD1. BLE interfaces over UART. There is an RS232 interface for WLAN debugging which should be broken out to headers. The symbol, footprint and 3D model can be downloaded from UltraLibrarian for any ECAD software: https://app.ultralibrarian.com/Details/ ... 7111&tab=m. For getting started on building the Ti WiLink8 Kernel module, take a look at this wiki: http://processors.wiki.ti.com/index.php ... e_Linux.29
Posted: Mon Jan 14, 2019 10:23 pm
by jrschueler
JBDynamics: Were you successful at implementing the TiWi-BLE chip with the CM3 running 4.14.71 kernel?
I am doing the same, I used the in-tree kernel drivers which supplied WLCORE, WLCORE_SDIO and WL12XX. I applied all other tools from WL18XX build scripts. I struggled with the DT but finally managed to get he WLAN up and running. However, I cannot get the WLAN_EN pin to be toggled by ifconig wlan0 UP/DOWN. My device tree voltage regulator (wlan_en_regulator) is working fine and mapped correctly. As a workaround, I currently have the voltage regulator set to "always-on" which brings up wlan0 at boot. I also tried "regulator-boot-on", which it is initialized but is quickly disabled, then nothing. My SDIO node includes the vmmc-supply = <&wlan_en_reg>; but seems to be doing nothing.
I am guessing this is a driver related issue, as the voltage regulator works independently and every other part of the WL1271 is working. Just they are not talking to each other. I wanted to know if you had a similar issue or if anybody else could help. I tried compiling the wlcore/wl12xx drivers manually from the ti WL18XX build scripts but ran into errors with the newer 4.14.71 kernel. Any advice is appreciated
Posted: Wed Feb 06, 2019 2:42 am
by rahmanuh
Hi jrschueler,
I am trying to turn the WiFI on at my CM3. I use WL1273 chip as the WiFi card. After built a kernel with WL12xx module loaded, and setup the pin configuration (in a overlay dts) like this:
GPIO 34: level=0 fsel=7 alt=3 func=SD1_CLK
GPIO 35: level=1 fsel=7 alt=3 func=SD1_CMD
GPIO 36: level=1 fsel=7 alt=3 func=SD1_DAT0
GPIO 37: level=1 fsel=7 alt=3 func=SD1_DAT1
GPIO 38: level=1 fsel=7 alt=3 func=SD1_DAT2
GPIO 39: level=1 fsel=7 alt=3 func=SD1_DAT3
GPIO 42: level=0 fsel=0 func=INPUT >> as WL_IRQ
GPIO 43: level=0 fsel=1 func=OUTPUT >> as WL_EN. But right now I just hook the WL_EN (on WL1273 side) to 1.8V to make it always HIGH.
Unfortunately I still failed to make the WiFI on. Nothing happen. Even I always get make-error when try to do the steps from http://processors.wiki.ti.com/index.php ... d_Scripts .
Do you mind to provide the step what you did to make the WiFi on?
It would be nice if I can contact you in person :)
regards,
Rahmanu
Posted: Mon Feb 11, 2019 6:14 pm
by cusna
Hello everyone, I would like to start a project with a CM3 + adding a Wi-Fi and BT module.
Alone I can not and I would be willing to pay those who help me. I was thinking of using the LBEH5HY1MW of the Murata where it uses the CYW43455 which is lost to the Raspberry Pi 3 B +, but I could also change and use another one.
Someone is willing to help me?
Thank you
Posted: Tue Mar 05, 2019 10:39 am
by GLRobotics
jrschueler: NOOB here, struggling as well, can you elaborate or link to what you did in DT in order to have WLAN up?
jrschueler wrote: I struggled with the DT but finally managed to get the WLAN up and running
Posted: Wed Apr 17, 2019 12:50 pm
by Jojo85
Hey, thanks for those informations, i will try to use ur solution. I just have a few questions. I have the CM1 with intergrated memory, i want to connect it to the internet via wifi and connect mouse and keyboard with bluethoot. What software do i need to install and can you give some instructions how its done. Its my first time doining it. Btw im using eagle so if u coule send me the footprints that would be awsome. Im not sure if the pinout is the same but ill check it.
kind regards jojo
Posted: Thu Apr 18, 2019 7:30 am
by antoinebore
Does somebody succeed in getting the wilc1000 driver works ?
Posted: Tue May 07, 2019 9:24 pm
by sumanth_shenoy
I am also trying to build driver for wl1807 and following the process as given in the following link : http://processors.wiki.ti.com/index.php ... ld_Scripts
But its not taking me anywhere,
I am using default paths for kernel and toolchain in setup-env file.
Can you please share any documents or method you used in building the driver and how you accessed devvice tree file in using wl12xx and other drivers?
Posted: Tue May 28, 2019 9:32 am
by mayanksonu11
Hello Everyone!! Can you please tell me whether I can use ESP32 in any way to get the wifi connectivity to the whole OS but not just the script (in case you want me to suggest AT commands). I have also gone through adding the peripherals in Device tree overlays but it seems working with that too requires hardware driver. And I could not find any driver of ESP32 on the web. So kindly let me know whether working with ESP32 will be feasible or not.
Posted: Thu Jul 04, 2019 10:38 am
by raja2n
Could you please share me your experience on this esp32 module wifi connectivity. I am also looking for replacement for LAN connection , the wifi module should support full internet access instead of playing with AT commands. Is there any way to make esp module as internet over uart from Rpi compute module.
Any one have any suggestion, it will be more helpful
Posted: Thu Jul 04, 2019 11:30 am
by IOTON
Buy some amount of different wifi usb dongles, test it, disassemble dongle you like and copy circuit.
Posted: Wed Jul 10, 2019 3:39 am
by rlev
Thank you
Hi cusna.
Were you be able to interface successfully the LBEH5HY1MW and the CM3 Plus board ?
Posted: Mon Nov 25, 2019 8:07 am
by danny2312
Does anyone use rtl8812au on compute module 3?
I followed this web https://github.com/gnab/rtl8812au.
But my CM3 still can not detect this wifi module.
Any advice is appreciated.
Posted: Thu Mar 05, 2020 4:10 pm
by paolos
Hello everyone, I would like to start a project with a CM3 + adding a Wi-Fi and BT module (chip TI wl1837).
I followed the guide
https://processors.wiki.ti.com/index.ph ... ld_Scripts
but I'm having troubles completing the procedure.
Especially in the compilation phase.
There is someone who can publish the correct configuration of the setup-env file and configuration.sh file ?
Or in any case one idea for correct procedure to link this chip ?
thanks
