NifAres
CM3 rpiboot get serial number
Tue May 09, 2017 10:16 am
Does anybody have a solution to get CM3 serial number when it is connected to HOST in flash mode?
After setup CM3 in flash mode in lsusb -v I got
Bus 001 Device 048: ID 0a5c:0001 Broadcom Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0a5c Broadcom Corp.
  idProduct          0x0001
  bcdDevice            0.01
  iManufacturer           2 Raspberry Pi
  iProduct                1 Compute Module
  iSerial                 3 0001
iSerial is 0001 and not real CM serial number that I can get via i.e. /proc/cpuinfo on CM running linux.
Of course, I can try to make a workaround to get this serial number:
  • * setup CM in flash mode
    * write image with working OS to save serial number in a file on eMMC
    * boot CM and wait a some time
    * setup CM in flash mode again
    * read serial number from that file
    * flash final OS image
But, is there a simpler way?
Serafin W.
Senior System Architect @ Binartech ( www.binartech.com )
jrychter
Re: CM3 rpiboot get serial number
Mon May 22, 2017 12:30 pm
Anyone?
Reading the serial number (or the MAC) at rpiboot stage is important in production. When mass-producing devices with CM modules, one usually needs to program the onboard flash and read the MAC address (for printing stickers, keeping a database of devices, etc). If this requires an additional power down/reboot step, it significantly complicates things and makes production more costly because of the additional time wasted and added complexity.
I am assuming this is not a problem technically — but it is not something that can be done without help from the authors of usbboot/rpiboot.
--J.
Founder at PartsBox: https://partsbox.io/ (keep track of your electronic components)
gsh
Mon May 22, 2017 12:54 pm
It would be possible to add the board revision as the USB serial number...
Will try and add it with the next bunch of changes
Gordon
Gordon Hollingworth PhD
jrychter
Mon May 22, 2017 1:35 pm
Board revision?
To clarify: what is actually needed is the MAC address. This seems to be derived from the CM serial number. Board revision isn't that helpful.
--J.
NifAres
Mon May 22, 2017 8:00 pm
As USB serial number is required to got CM serial number, not revision number.
Exactly that we can get, when we run on CM eg.
$ cat /proc/cpuinfo | grep 'Serial'
Serial		: 000000006fd07946
or
$ vcgencmd otp_dump | grep '28:'
28:6fd07946
Serafin W.
NifAres
Fri May 26, 2017 7:26 pm
Thank you very much Gordon.
Today's version of rpiboot has what we need.
Regards
Serafin W.
Return to “Compute Module”
