MikeDJohnson
using bcm2835-smi-dev on CM3
Mon Feb 20, 2017 8:59 am
Looking at interfacing the CM3 to an FPGA using the SMI. As usual with BCM, limited documentation is a problem.
The bcm2835-smi-dev looks like a good starting point, and I can load the device tree overlay and see the kernel module is loaded with lsmod.
Looking at the driver code, it should register the device, however I don't see anything in /dev.
The bcm2835-gpiomem driver looks very similar in the registration, and we get a /dev/bcm2835-gpiomem
I didn't think mknod was needed nowadays?
Any pointers would be appreciated - especially an app snippit which opens any of the SMI drivers :)
I'm currently basing the hardware directly with /dev/mem which is fine, but I would want to modify or use a kernel driver eventually.
Many thanks,
Mike
MikeDJohnson
Re: using bcm2835-smi-dev on CM3
Fri Aug 25, 2017 9:36 am
Thanks (I just saw your reply). I have the driver, but no additional documentation is available yet?
I am designing the hardware on the other side of the interface, and modifying the timing without any register details is a pain.
Best,
Mike
gsh
Fri Aug 25, 2017 9:43 am
Luke wrote the include file to cover the documentation...
https://github.com/raspberrypi/linux/bl ... 2835_smi.h
That contains all the information concerning the register definitions when it comes to timing, there isn't much else otherwise.
Gordon
Gordon Hollingworth PhD
kmuffsfpv
Mon Mar 05, 2018 7:41 am
I was thinking of doing the same. Did you get this working?
Return to “Compute Module”
