I have just ordered a compute module 3 and 2 cameras from RS. The kit does not include camera adapters, and as far as I can see, they are only available if I buy a compute module 1. Can they be sourced independently?
Thank you.
Yes one needs the Development Board kit to obtain the adapters;jamesh wrote:I thought they came with the IO board? Since they cannot connect directly to the CM1/3, only the IO board, that is why they are packaged like that.
Only 1 per kit ?fruitoftheloom wrote:Yes one needs the Development Board kit to obtain the adapters;jamesh wrote:I thought they came with the IO board? Since they cannot connect directly to the CM1/3, only the IO board, that is why they are packaged like that.
http://cpc.farnell.com/raspberry-pi/rpi ... dp/SC14356
If one is creating a base board you would use the standard connectors as used on the Rpi B models....
Ambiguity rulesgordon77 wrote:Only 1 per kit ?fruitoftheloom wrote:Yes one needs the Development Board kit to obtain the adapters;jamesh wrote:I thought they came with the IO board? Since they cannot connect directly to the CM1/3, only the IO board, that is why they are packaged like that.
Contents:
Raspberry Pi Compute Module I/O Board, Raspberry Pi Compute Module 3, Raspberry Pi Compute Module 3 Lite , Raspberry Pi Compute Module I/O Board Camera Display Adaptor, 5v 2.5A Power Supply, USB A to micro B cable and 4x Jumper wires
