CM3 + IoT
Posted: Mon Feb 06, 2017 12:30 pm
by C73
Any experience with CM3 + IoT ?
Re: CM3 + IoT
Posted: Mon Feb 06, 2017 12:43 pm
by fruitoftheloom
C73 wrote:Any experience with CM3 + IoT ?
Welcome, please can you clarify. Internet of Things is a very generic term:
https://en.wikipedia.org/wiki/Internet_of_things
Re: CM3 + IoT
Posted: Mon Feb 06, 2017 12:49 pm
by C73
sorry, I specify: any experience with running Windows IoT on CM3 ?
Re: CM3 + IoT
Posted: Mon Feb 06, 2017 1:17 pm
by fruitoftheloom
C73 wrote:sorry, I specify: any experience with running Windows IoT on CM3 ?
It is not listed as a supported platform for Windows 10 IoT Core:
viewtopic.php?f=105&t=172902
https://developer.microsoft.com/en-us/w ... iceoptions
You really should contact Microsoft so they are aware of users wishing to use the Compute Module 3 for their IoT Operating System as there will need to be a mechanism to flash the eMMC from the IoT Dashboard in Windows 10. Though whether or not 4GB is sufficient may be an obstacle.
Possibly a CM3 Lite may work, but again have Microsoft updated the kernel/firmware ???
Re: CM3 + IoT
Posted: Tue Feb 07, 2017 8:13 am
by C73
Thank you for the answer.
In fact I am then just a little surprised by the features announced at the launch of the product:
https://www.raspberrypi.org/magpi/compute-module-3/
http://in.pcmag.com/laptops/111608/news ... r-than-cm1
Re: CM3 + IoT
Posted: Tue Feb 07, 2017 8:43 am
by DougieLawson
IoT can be and is done using Linux. You ARE NOT forced to use Win10IoT to run your IoT project.
Re: CM3 + IoT
Posted: Thu Feb 09, 2017 9:35 pm
by VAXpascal
DougieLawson wrote:IoT can be and is done using Linux. You ARE NOT forced to use Win10IoT to run your IoT project.
Awesome answer.
I was wondering what the response was to using a MS product in general on RPi. I imagine most are attracted to RPi as a way around companies like them.
Re: CM3 + IoT
Posted: Sun Feb 12, 2017 8:33 pm
by RpiName
Sure, here is one nice, *modern* application:
https://youtu.be/-SMKos1NxQI
For more details:
https://www.linux-projects.org/2016/12/ ... epresence/
which actually is *one* example of how to use the UV4L framework:
Re: CM3 + IoT
Posted: Fri Jun 22, 2018 12:25 am
by IoT Chris
We are currently using CM3L with only 1 single issue...
We cannot access any of the pins that are not available on the Raspberry Pi 3, that is we can only access the first bank of IO. Apart from that it has been working like a charm! Raspbian has no issue accessing the full capabilities of the CM3L and we have verified all wiring using Raspbian.
If anyone has any advice I have tried to find support through sack exchange but have not had any responses yet: https://raspberrypi.stackexchange.com/q ... s-iot-core
Re: CM3 + IoT
Posted: Fri Jun 22, 2018 12:11 pm
by gsh
How are you trying to access them, through /sys or through a c implementation like raspi-gpio
Gordon
