sorbonne
CAM0 not detected on CM3
Sun Jan 22, 2017 11:16 pm
I followed all the official instructions to enable both the 2.1 cameras on the CM3, however I get the following:
$ vcgencmd get_camera
supported=2 detected=1
CAM0 is not detected. I doubled checked the cable connections, they are ok.
I am using the official -dual.dts:
sudo dtc -I dts -O dtb -o /boot/dt-blob.bin dt-blob-dualcam.dts
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@default has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p3 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p4 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p5 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p6 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p7 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p8 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p9 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p10 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p11 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p12 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p13 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p14 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p15 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p16 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p17 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p18 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p19 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p20 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p21 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p22 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p23 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p24 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p25 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p26 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p27 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p28 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p29 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p30 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p31 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p32 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p33 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p34 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p35 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p36 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p37 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p38 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p39 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p40 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p41 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p42 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p43 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p44 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p45 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p46 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p47 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p48 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p49 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p50 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p51 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p52 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_config/pin@p53 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@NUM_CAMERAS has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@CAMERA_0_LED has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@CAMERA_0_SHUTDOWN has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@CAMERA_0_UNICAM_PORT has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@CAMERA_0_I2C_PORT has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@CAMERA_0_SDA_PIN has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@CAMERA_0_SCL_PIN has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@CAMERA_1_LED has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@CAMERA_1_SHUTDOWN has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@CAMERA_1_UNICAM_PORT has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@CAMERA_1_I2C_PORT has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@CAMERA_1_SDA_PIN has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm/pin_defines/pin_define@CAMERA_1_SCL_PIN has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@default has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p3 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p4 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p5 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p6 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p7 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p8 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p9 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p10 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p11 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p12 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p13 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p14 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p15 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p16 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p17 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p18 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p19 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p20 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p21 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p22 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p23 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p24 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p25 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p26 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p27 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p28 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p29 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p30 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p31 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p32 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p33 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p34 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p35 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p36 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p37 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p38 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p39 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p40 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p41 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p42 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p43 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p44 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p45 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p46 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p47 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p48 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p49 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p50 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p51 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p52 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_config/pin@p53 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@NUM_CAMERAS has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@CAMERA_0_LED has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@CAMERA_0_SHUTDOWN has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@CAMERA_0_UNICAM_PORT has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@CAMERA_0_I2C_PORT has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@CAMERA_0_SDA_PIN has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@CAMERA_0_SCL_PIN has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@CAMERA_1_LED has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@CAMERA_1_SHUTDOWN has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@CAMERA_1_UNICAM_PORT has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@CAMERA_1_I2C_PORT has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@CAMERA_1_SDA_PIN has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /videocore/pins_cm3/pin_defines/pin_define@CAMERA_1_SCL_PIN has a unit name, but no reg property
Version: DTC 1.4.1-gbd1c3aca-dirty
after rpi-update nothing changed.
Do you know what to check?
6by9
Re: CAM0 not detected on CM3
Mon Jan 23, 2017 1:15 pm
Have you enabled "dtparam=arm_i2c" in config.txt or otherwise reused GPIOs 2&3?
"sudo apt-get install raspi-gpio" "sudo raspi-gpio get" and report the config of GPIOs 0-3 and 28-31 (or just post the lot).
sorbonne
Mon Jan 23, 2017 6:43 pm
solved,thanks. I had to replace one broken cable.
daveshorts
Wed Feb 08, 2017 11:27 am
I am getting the same problem with a Compute Module 1 on jessie, but I have tried swapping all the 1 & 0 cameras and cables. cs 0 (CAM1) always works and cs 1 (CAM0) never does.
I get the following error
mmal: Could not select camera : error 3
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
I have updated everything
when I make the blob from the dt-blob-dualcam.dts found on
https://www.raspberrypi.org/documentati ... -camera.md
dtc -I dts -O dtb -o dt-blob.bin dt-blob-dualcam.dts
I get the
errors
The output of sudo raspi-gpio get
GPIO 00: level=1 fsel=0 alt= func=INPUT
GPIO 01: level=1 fsel=0 alt= func=INPUT
GPIO 02: level=0 fsel=1 alt= func=OUTPUT
GPIO 03: level=0 fsel=1 alt= func=OUTPUT
GPIO 28: level=1 fsel=4 alt=0 func=SDA0
GPIO 29: level=1 fsel=4 alt=0 func=SCL0
GPIO 30: level=0 fsel=1 alt= func=OUTPUT
GPIO 31: level=0 fsel=1 alt= func=OUTPUT
The difference strikes me a not right, but I don't know what it should look like.
I guess it could be a damaged IO board connector...
Any ideas?
thanks
Dave
daveshorts
Wed Feb 08, 2017 12:54 pm
Ok, I have tried with a different IO board, and exactly the same problem. Am I doing something wrong with the software?
cheers
6by9
Wed Feb 08, 2017 12:57 pm
daveshorts wrote:The output of sudo raspi-gpio get
That is correct. Both camera modules have the same I2C address so can't both be connected to the peripheral at the same time. The GPU firmware changes the pin muxing as it finds it needs to access the other set of pins.
For test purposes only, and only on a CM1, try adding "dtparam=i2c_vc=on" to /boot/config.txt
sudo modprobe i2c-dev
sudo raspi-gpio set 0 a0
sudo raspi-gpio set 1 a0
sudo raspi-gpio set 28 ip
sudo raspi-gpio set 29 ip
sudo raspi-gpio set 3 op dh
sudo i2cdetect -y 0
For a V1.3 OV5647 camera module you should see a response on 0x36, or 0x10 for a V2.1 IMX219 camera.
sudo raspi-gpio set 3 op dl
sudo raspi-gpio set 0 ip
sudo raspi-gpio set 1 ip
sudo raspi-gpio set 28 a0
sudo raspi-gpio set 29 a0
sudo raspi-gpio set 31 op dh
sudo i2cdetect -y 0
Will be doing the same for the other camera interface.
(If you're using some cloned OV5647 camera boards then you may need to set GPIO 2 or 30 high as well - they weren't 100% accurate in their cloning)
If either of those don't show up the expected I2C address then you need to investigate your wiring. Don't forget to remove the "dtparam=i2c_vc..." from config.txt once done. Having both processors trying to access the one peripheral will cause issues.
The warnings from dtc are because version 1.4 (IIRC) complains more than earlier versions. Add -q to the command-line to shut up some of the warnings.
daveshorts
Thu Feb 09, 2017 6:18 pm
Thankyou
It would appear that I am a complete numpty, and managed to swap over two similar coloured wires.
sorry for wasting your time...
thanks for your patience
paulsk
Sun Apr 16, 2017 3:29 pm
I had the same problem with trying to use a new Wide Angle Camera with a CM3 on a CM3 IO board. I could not get it working with a CM3 but the same camera worked good with a Raspberry Pi model 3B.
Therefore I went back to the CM3/CM3IO combo to try and get them to work.
The jumper wires on the MC3IO board were as follows:
CD0_SDA to GPIO bank 0 (J5) pin 0
CD0_SCL to GPIO bank 0 pin 1
CAM0_IO1 to GPIO bank 0 pin 2
CAM0_IO0 to GPIO bank 0 pin 3
CD1_SDA to GPIO bank 1 (J6) pin 28
CD1_SCL to GPIO bank 1 pin 29
CAM1_IO1 to GPIO bank 1 pin 30
CAM1_IO0 to GPIO bank 1 pin 31
When I connected the camera to CAM1
the result of vcgencmd get_camera was:
When I connected the camera to CAM0
supported=2 detected=0
With the camera connected to "CAM1", running a camera test with a python script resulted in the PiCamera error: "no data received from sensor."
Then I modified the file /boot/dt-blob-dualcam.dts. I deleted the section "pins_cm", so I only had left over the section "pins_cm3". I compiled this modified .dts into dt-blob.bin. I just wanted to rule out a possible "mix" or "confusion". Because I use a CM3 I wanted less "complexity" in the .dts file (at least during this stage of troubleshooting).
After rebooting I ran the command "raspi-gpio get". I saw the following (I only copy here the lines that took my attention):
BANK0 (GPIO 0 to 27):
GPIO 02: level=0 fsel=4 alt=0 func=SDA1
GPIO 03: level=0 fsel=4 alt=0 func=SCL1
BANK1 (GPIO 28 to 45):
So I came to the conclusion that I had wired the jumper wires in a reverse way than shown in the images in the instructions found on: http://www.raspberrypi.org/../cmio-camera.md.
The jumper wires on my CM3IO board had to be "reversed", I mean: GPIO 28 --> BANK0 pin 0 etcetera, as shown below:
CD0_SDA to GPIO bank 1 (J6) pin 28
CD0_SCL to GPIO bank 1 pin 29
CAM0_IO1 to GPIO bank 1 pin 30
CAM0_IO0 to GPIO bank 1 pin 31
CD1_SDA to GPIO bank 0 (J5) pin 0
CD1_SCL to GPIO bank 0 pin 1
CAM1_IO1 to GPIO bank 0 pin 2
CAM1_IO0 to GPIO bank 0 pin 3
With this "new" wiring and connecting the camera connected to "CAM0",
the command: "vcgencmd get_camera" now resulted in: "supported=2 detected=1". A run of the python camtest.py script executed without error. It produced images and it created image capure files 'xxx.jpg' and video files 'xxx.h265'.
Sure I am a little proud of myself that I solved this camera problem myself. This result was only possible through all the good documentation available on the internet, especially here on raspberrypi.org.
Sofar the result of my troubleshooting.
6by9
Sun Apr 16, 2017 5:13 pm
paulsk wrote:I had the same problem with trying to use a new Wide Angle Camera with a CM3 on a CM3 IO board. I could not get it working with a CM3 but the same camera worked good with a Raspberry Pi model 3B.
You've almost certainly added "dtparam=i2c_arm=on" to your config.txt file. That is enabling i2c-1 on GPIOs 2&3 which you have already assigned to CAM1_IO[0|1] - they can't have two functions.
If you need i2c-1 for your application, then either move it to other pins, or alter your dt-blob.bin to move CAM1_IO[0|1] elsewhere (eg 4&5).
paulsk
Sun Jun 11, 2017 9:13 am
Thank you. As of 8 of June I possess 2 of these wide-angle cameras, both with a flat cable of about 75cm. They are now both detected. I have them now working.
Return to “Compute Module”
