W. H. Heydt
Re: CM3 Release Date
Fri Oct 14, 2016 4:15 am
jamesh wrote:
PeterO wrote:I read that NEC are using a custom spin of the CM from element14, so it may not actually be the same as a CM3 that eventually becomes available to everyone.
PeterO
I don't know, but they could be using a CM3Lite, and have the eMMC on the carrier.
Having watched the NEC announcement video, it is my impression that the CM slot in the monitors can use either a stock CM/CM3 or the custom NEC CM3-16, depending on your needs. This would argue against the eMMC being on the carrier board. Also...while the CM3L exposes the SD interface, I'm not at all sure that the eMMC *could* be on the carrier board and still work.
Now that I think about it, there isn't anything I've seen suggesting that the eMMC interface is exposed off the board, anyway.
mic_s
Fri Oct 14, 2016 8:08 am
clk, cmd and data[0] ... data[7] : GPIO34-GPIO43 (Alt3) , SODIMM pin 52 ... pin 78
gregeric
Fri Oct 14, 2016 8:31 am
The Pi's primary SD/eMMC interface is 4-bits wide at GPIO48-53. That's the one broken out on even numbered pins 2-24.
CM3(L) & revised IO board schematics now at https://www.raspberrypi.org/documentati ... ematics.md
Vbat now straight to 5V re core power - a simple mod to do on the old CMIO board if required.
Remove R1 & run a wire from the pad nearest the CM socket to one of the caps as shown.
W. H. Heydt
Fri Oct 14, 2016 1:39 pm
Blog post today (14 Oct.) is about the NEC announcement and says (in part) that the CM3 will be released "near the end of the year". As I read it, it also says that that the CM1, CM3, and CM3-16 will all work in the NEC displays.
JamesPi123
Thu Apr 13, 2017 8:45 pm
where?
Thu Apr 13, 2017 8:52 pm
Retired disgracefully.....
......to a more gentile life !
W. H. Heydt
Fri Apr 14, 2017 1:02 am
W. H. Heydt wrote:
hippy wrote:
W. H. Heydt wrote:What intrigues me about the NEC announcement is the NEC "special" CM3 with 16GB of eMMC (aka CM3-16). The two interesting items (for me) in the datasheet are that the CM3 will still have 4GB eMMC (I was hoping for more) and the CM3L, without any eMMC.
If the CM3 and CM3L use the same PCB, if it's just that an eMMC isn't fitted to the CM3L but the tracking is there, it would seem to be trivial to fit any sized eMMC memory.
Well...BGA soldering isn't in my skill set, but other than that, one would think that was possible.
There is one other--rather critical--difference. The CM3L routes signals to use an external SD card or eMMC, while the CM3 does not. Therefore, one would have to either remove the eMMC from a CM3 and replace it or put the eMMC on the carrier board for a CM3L.
Return to “Compute Module”
