Camera / display connectors
Posted: Sun May 01, 2016 9:52 am
by leol
This is a really dumb question, but I can't see how these connectors work. Which bit pulls up or opens? I don't want to break them.
Leo
Re: Camera / display connectors
Posted: Sun May 01, 2016 9:56 am
by DougieLawson
Posted: Sun May 01, 2016 9:59 am
by leol
DougieLawson wrote:Does this video help: https://www.raspberrypi.org/help/camera-module-setup/
No, I'm afraid not, it shows a raspberry pi not a compute io board and the connectors are different.
Leo
Posted: Sun May 01, 2016 11:12 am
by DougieLawson
The connectors are the same basic design. Tug the clip gently until it moves, slide the cable in, press the clip home.
Posted: Sun May 01, 2016 5:12 pm
by leol
DougieLawson wrote:The connectors are the same basic design. Tug the clip gently until it moves, slide the cable in, press the clip home.
Thanks. Sorry to be stupid, do you tug forwards, backwards, or up?
Leo
Posted: Sun May 01, 2016 5:21 pm
by DougieLawson
tug parallel to the small circuit board.
Posted: Mon May 02, 2016 12:00 pm
by leol
DougieLawson wrote:tug parallel to the small circuit board.
Thanks, but I must be being very stupid, Still can't do it and niw have broken one of the connectors. I guess I'll give up!
Posted: Mon May 02, 2016 12:31 pm
by MarkHaysHarris777
now I have broken one of the connectors
Uffda!
leol wrote: Thanks, but I must be being very stupid
You don't seem to have much finesse, but I think 'stupid' might be too harsh a label to pin on oneself.
leol wrote:Still can't do it ... guess I'll give up!
Never give up; sooner or later, you'll get it right.
:mrgreen:
Posted: Mon May 23, 2016 7:15 am
by leol
Update - With the release of the new Zero with the same connectors, I have taken advantage of a couple of videos people have posted and can now see how to use the connector.
I had not realised that it is the small black part of the connector rather than the bigger white part that moves.
Easy when you know how.
Leo
Posted: Mon May 23, 2016 2:11 pm
by W. H. Heydt
Slightly off topic...has anyone tried using the Pi Zero camera cable with a dev CM carrier board? I've seen pictures of using the dev carrier adapter boards with a Pi Zero, so the reverse hook up *ought* to work....
Posted: Wed May 25, 2016 7:28 am
by Frederir
To the best of my knowledge the Pi Zero camera connector is the same as the CM connector. So a Pi Zero camera flex should work directly on CM.
Waiting for PI zero schematic to be sure.
Posted: Wed May 25, 2016 2:14 pm
by W. H. Heydt
Frederir wrote:To the best of my knowledge the Pi Zero camera connector is the same as the CM connector. So a Pi Zero camera flex should work directly on CM.
Yes, the connector is that same, and--yes--the cable should work. I just haven't seen anyone say that they have actually done so.
Posted: Thu Feb 16, 2017 7:24 pm
by TheBlackSheep
I've managed to break two of these little black clamps trying to swap the DISP0 and DISP1 connectors - they are really fragile.
Has anyone got a part number (RS, CPC or wherever) so I can try and replace the clamps on the broken ones.
TheBlackSheep
Posted: Sat Feb 18, 2017 2:12 pm
by aBUGSworstnightmare
Molex 54548-2271
http://www.digikey.de/product-detail/en ... ND/3197258
The black part of the connectors needs to be pulled (for opening) or pushed (for closing) carefully in a horizontal movement. THEY DO NOT FLIP CLOSE/OPEN!
